Hello everyone, I was wondering if there is anyway to convert directly to DVD while capturing via Firewire???Thanks!
Not directly, but an encoder like Mainconcept can convert to MPEG-2 on the fly from a FireWire input, then all you need to do is author it to DVD and burn. But you need a fast computer to do this.
And the quality will generally be lower than using a encoder to convert from your transfered files on a hard drive.
A lot easier would be a DVD recorder with FireWire inputs and burn directly to disc.
Send DV through Firewire to a DVD recorder
By nlec in forum ProgrammingReplies: 21Last Post: 20th Aug 2014, 10:44 -
Firewire device to computer with no Firewire
By dbuser2 in forum ComputerReplies: 11Last Post: 24th Sep 2010, 20:32 -
TV laptop firewire dvd player
By c-raig in forum Newbie / General discussionsReplies: 2Last Post: 20th Jun 2010, 05:32 -
DVD player with Firewire (1394) out
By PizzaPete in forum Capturing and VCRReplies: 9Last Post: 23rd Oct 2008, 00:05 -
Motherboard Firewire versus Add-in Card Firewire
By SCDVD in forum Newbie / General discussionsReplies: 7Last Post: 19th Jun 2008, 11:19
Thanks!
