Hello everybody
I have a small problem, sometimes after I restart the computer I get the windows with the safe mode screen...any ideas why that might happen? After I restart the computer again then everythings turns to normal but still the problem is a little annoying.
Thanks in advance
I did check the link but the thing is that I don't have the safe boot box checked, so this means that the problem is coming from somewhere else...Originally Posted by Bjs
http://www.supportminds.com/pc-tips/my-system-keeps-starting-in-safemode.html?c=1
Then in safe mode , run chkdsk c: /f
Change c to reflect os drive .
Run command , enter msconfig
Goto startup tab , disable all non-essential programs , such as nero incd , adobe , messenger , printer utilities , ect .
Click apply , ok ... system restarts .
Adaware se + avgfree , install , update , runs scans ... if avgfree picks up anything , remember to remove from virus vault , or a service denial error can occur (no access to internet)
Hijackthis , systems scan , send log by pm .
The other thing that has been known to cause this problem is power interruptions , which might lead to an issue with a system driver becoming corrupted .
If you have the os cd , you could > Start > Run > SFC /SCANNOW
But , do not do this without the os cd ... it'll pester the crap out of anyone with popups till it finishs .
Try unistalling video drivers ... if issue with current drivers occurs , it might be looping it into safe mode .
I've seen this happen a few times .
Check bios setup is correct according to manual (video setup for onboard where available)
If addon video card , and motherboard has onboard , remove addon , and use only onboard ... if that works , then addon has suffered an issue and should be replaced .
Can't connect to Internet in Safe Mode
By alegator in forum ComputerReplies: 10Last Post: 4th Apr 2012, 13:50 -
Connecting to the internet in safe mode
By hellfire45 in forum ComputerReplies: 0Last Post: 1st Dec 2010, 20:23 -
Cannot change resolution when in safe mode
By mysts in forum ComputerReplies: 5Last Post: 23rd Oct 2008, 13:24 -
WindowsXP is @#%ed - how to burn CD from safe mode?
By sdsumike619 in forum ComputerReplies: 7Last Post: 19th Oct 2008, 23:16 -
help! i can only boot in safe mode
By ted demen in forum Newbie / General discussionsReplies: 30Last Post: 6th Jun 2007, 07:51
