I've been using ffmpegx for a while now to convert avi files to mp4 format for importing to iTunes, for viewing on my Apple TV - however I seem to be losing video quality. The AVI files are HD / DVD quality...can anyone recommend the optimum settings for this type of conversion to produce the best video quality? Thanks!!
There's *always* a tradeoff between filesize and quality. If you want high quality, you'll have to accept large files. If the quality of the output is not to your liking, you'll need to increase some combination of resolution (if you are unhappy with that particular aspect of the output) and bitrate (if you don't like the macroblock artifacts during high-motion scenes). The judgment of whether it's good enough is very much a function of the target display device, as well as personal taste, so you'll have to try a few things and see what works for you.
To guide you in your search, ffmpegx helpfully changes the color of the bitrate to convey an approximate idea if you are using an unnecessarily high bitrate (by changing the color of the text to purple), or an insufficient one (with red text). If its choices aren't to your liking, work upward from there.
How to make an AVI better quality (keeping output still as AVI)?
By Dogpoundz in forum Video ConversionReplies: 15Last Post: 22nd Sep 2011, 01:12 -
Converting ITunes protected video to AVI for DVD
By jessejames in forum Video ConversionReplies: 5Last Post: 12th Jun 2010, 18:25 -
avi 2 itunes
By kg4886 in forum Newbie / General discussionsReplies: 4Last Post: 22nd May 2009, 06:29 -
avi quality better then vhs quality?
By NateDizzle in forum Video ConversionReplies: 7Last Post: 11th Jun 2007, 09:20 -
3gp to avi decent quality requires iTunes, Dr DivX and Virtualdub!
By Dannyfoster in forum Newbie / General discussionsReplies: 0Last Post: 4th Jun 2007, 16:51
