Hi everyone,
I've asked this question before, but I thought I'd see if anyone has any new insights concerning scanning labels that are shiny and reflective? I've tried putting a piece of tracing paper or frosted Plexiglas on the flatbed before scanning -- though that got rid of the multi-color effect, tracing paper shows too much fiber on the scan, and frosted Plexiglas really dulls the label image. I am basically not happy with either methods; and I'm wondering if anybody has new ways of scanning? Despite the less-than-satisfactory results, I think it'll still be easier than trying to get rid of the rainbow hues in Photoshop...
Any thoughts will be greatly appreciated. Thanks in advance!
Spiffy
Have you tried descreening in your scans. Your rainbow hues are a moire pattern and descreening may help.
Other wise you probably need a polarizing filter to sit on the scanner bed. -
I raise up one side of the disc with a paper clip spread out a litte.
Scan it, and then do the same thing to the exact other side.
I then use the clone brush to fix one image using the other.
If the whole thing is silver except for a small part, I usually create a custom one using the Box art work -
I use a Canon scanner; and it only has on/off when it comes to descreen -- so even though it does descreen, it doesn't do it nearly enough to get rid of the moire patterns or the rainbow effect.Originally Posted by oldandinthe way
I did a casual search, and seems like all polarizing filter for sale are only the circular kind made for camera lenses.
I had actually gotten two kinds of acrylic pieces from my local plastic store; one was the frosted type as I mentioned; the other was a straight anti-glare but clear plexi. The frosted dulls the label too much; the clear anti-glare didn't deflect enough. I wonder if I will increase the anti-glare effect by double-up on the clear kind? -
I think the time is better spent creating a custom label. There is no reason to duplicate the shiny silver of the disc anyway, it can't be printed (not accurately anyway). Most titles, logos and such can be found around the web or even on the maufacturers website.
Google is your Friend
Video Cards revisited
By Seeker47 in forum ComputerReplies: 7Last Post: 24th Oct 2011, 11:32 -
photo scanning vs negative scanning
By lordhutt in forum ComputerReplies: 66Last Post: 7th Nov 2010, 19:09 -
AC-3 and Wave 5.1 frustration revisited...
By takearushfan in forum AudioReplies: 32Last Post: 19th Aug 2010, 14:54 -
MTS2AVI revisited
By RogerTango in forum Video ConversionReplies: 35Last Post: 28th Jun 2010, 17:08 -
Taiyo Yuden DVD -- are these shiny?
By lordsmurf in forum MediaReplies: 10Last Post: 21st Jan 2009, 14:45
