Someone has sent me some custom quicktime .mov files. I use Adobe Premiere Pro 2 (CS3 also) to edit with (I'm working on Win XP Pro & Vista Home Premium).
Here are the specs on the quicktime files:
320 x 180, 23.49 fps, Sorenson Video 3 compression
I'm not sure what type of project to create in Adobe Premiere Pro to handle simply importing these files and then editing them.
Should I make a custom template to match the frame size and fps as the mov files???
I'm not sure what editing mode to use either...(desktop, dv ntsc, dv 24p...etc)
Any suggestions would be highly appreciated!!!
Thank you.
Results 1 to 1 of 1
Sony Vegas Pro - Importing clips from another project
By ClownInBrown in forum EditingReplies: 8Last Post: 18th Apr 2011, 19:43 -
Export HDV clips to SD clips from Premiere Pro CS3
By foochuck in forum EditingReplies: 10Last Post: 8th Jun 2010, 17:03 -
Edit a HD project in Adobe Premiere pro 2?
By rajaa in forum EditingReplies: 12Last Post: 21st Apr 2009, 23:16 -
HV20 1080 24P project in Premiere Pro CS3
By kippard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 7th Feb 2009, 17:23 -
Adobe Premiere Pro 2.0 project file/autosave question
By wwervd316 in forum Newbie / General discussionsReplies: 0Last Post: 20th May 2008, 19:14
