I'm new to PC video editing. I'm looking for a basic capture card to digitise analog source video to AVI (with some compression) for editing in Adobe Premiere Pro.
Budget is a big limitation. A lot of the cheaper cards specify that they encode to MPEG2 etc but don't say you can capture the digital video into AVI files (such as DV-AVI or huff etc). My question is, can I assume it is possible to capture the digital video from a basic capture card using third party software and save/compress it to AVI files that would be suitable for intensive and frame accurate video editing?
Quality is not too great a concern - the source is Video8 and it will end up on a DVD, I just want something cheapish that will get the job done.
Any help or recommendations would be greatly appreciated.
Thanks!
Results 1 to 1 of 1
Recommend a <$100 capture card for analog to lossless AVI codec
By Cheesyii in forum Capturing and VCRReplies: 8Last Post: 27th Dec 2011, 08:49 -
Modern consensus on best sub-$250 lossless AVI-capable analog capture card?
By Mini-Me in forum Capturing and VCRReplies: 31Last Post: 9th Jul 2010, 05:18 -
Capture analog with camcorder or ATI card?
By Onceler2 in forum Capturing and VCRReplies: 7Last Post: 28th Nov 2009, 07:25 -
Capture problems HI8 analog to PC vi Terratec TV-card - Jitters ?
By gambla in forum Capturing and VCRReplies: 5Last Post: 16th Jul 2008, 08:51 -
new system capture card analog and dv
By rikit in forum Capturing and VCRReplies: 0Last Post: 27th Nov 2007, 19:44
