So basically I converted some rmvb files (with a frame rate of 23.000) to xvid using the shareware Alltoavi v4, resulting in xvid files with 128kps audio and a frame rate of 23. Then I used VirtualDubMod to extract the audio to wav, and AviSynth to create scripts for CCE. The scripts looked like this:
clip=AVISource("abc.avi", False)
aud=WAVSource("abc.wav")
AudioDub(clip,aud)
ResampleAudio(48000)
LanczosResize(720,480)
AssumeFPS(23.976, True)
ConvertToYUY2()
I then imported the avisynth files to CCE to convert these files into mpv and mpa files. I used the following settings: Audio Bitrate 224kps, Frame rate 23.976, 2:3 pulldown, 16:9 aspect ratio, since I intended to make NTSC DVDs.
I then imported the mpa and mpv files into DVD-Lab Pro where I made DVDs. However, when I import the mpv files into DVD-Lab Pro it thinks the frame rate is 29.97. G-spot thinks the frame rate is 29.97 too, but the pics/s is 23.976.
Anyways, when I compile the DVD, I get DVDs with slight audio sync problems (which I don't completely care about) and people with slightly higher voices. I'm wondering if this could be a frame rate problem, or a problem with DVD-Lab Pro settings (since the mpa files that I got from CCE don't seem to have high voices).
Does anyone have any ideas about why this is happening and how to fix it? Thanks in advance
Or could it be a problem with pulldown? Should I be using 3:2 instead of 2:3?
The framerate is 29.97 - that is the NTSC framerate for video playback. The actual framerate of the video is 23.976. The 3:2 pulldown applied during encoding accounts for the difference. That side of things is correct.
I would suggest that the problem lies somewhere in the base framerate change from 23 fps to 23.976 fps, or the re-sampling of the audio. I suspect both play a part. The framerate change accounts for the sync issue, the resampling accounts for the pitch change. If you demuxed the audio and did the length and sample rate changes in a good audio editor you would have neither problem.Read my blog here.
Problems with voices out of sync
By Jimbo1 in forum Video ConversionReplies: 4Last Post: 25th Apr 2011, 05:32 -
AutoGK Preview (High Pitch Voices)
By Blue_3 in forum AudioReplies: 0Last Post: 28th Mar 2008, 20:27 -
Increasing voices in 6ch audio
By silverwolf0 in forum Newbie / General discussionsReplies: 1Last Post: 23rd Aug 2007, 16:21 -
Music too high and Voices way too low?
By sensesfail86 in forum RestorationReplies: 4Last Post: 8th Jul 2007, 22:08 -
I've got audio sync problems (too)
By gigantibyte in forum EditingReplies: 26Last Post: 10th Jun 2007, 10:17
