I've got some video which I captured from my Panasonic DV camcorder using Sony Vegas (therefore .avi) I want to encode the video to Mpeg II and make DVDs out of the footage. My question is, what bitrate should I encode the files at? I want to utlize the best quality footage possible, while making sure most (if not all) DVD players can play the dvds without freezing up. I am going to encode the files with TMPGEnc, settings include DVD NTSC 16:9 (the footage was shot in widescreen and I want to retain that) CBR MPEG-1 Layer II Audio (MP2) and when going through the wizard the "recommended settings" are 8000 kbits/sec and audio at 384. Is this a good setting? Is it too high? I am mainly concerned about freezing on DVD players during playback.
Secondary question, is there much of a difference using CBR and VBR settings? Which one is preferable? Thanks!
yesOriginally Posted by RKelly
https://forum.videohelp.com/topic331240.html
your settings sound 'safe'
you'll want your audio in dolby.
do your audio separately, use an aften gui like encwavtoac3
tmpg plus is old...
gl -
I'm still using TMPGEnc Plus and use the "recommended" settings or lower video bit rate if I want to put more content on a particular disc. I've had no playback issues on my 8-year-old Panasonic and other, cheap, portables. I typically use AviSynth to input to TMPGEnc, though, mainly to resize to deal with the horrible overscan on the tube TV.
Cheers,
Jim
ISO file advice
By ehcah in forum Newbie / General discussionsReplies: 1Last Post: 3rd Dec 2010, 20:45 -
Bitrate and resolution advice.
By ShinKyo in forum Video ConversionReplies: 9Last Post: 20th May 2010, 14:01 -
Software that will allow to see what bitrate a movie or iso file is encoded
By Teac23 in forum DVD RippingReplies: 6Last Post: 21st Apr 2010, 20:22 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 13:03 -
Newbie needs bitrate calculation advice to convert my 1st PAL to NTSC
By queen_anne in forum Video ConversionReplies: 35Last Post: 20th May 2007, 22:48
