    Jul 2007
    hi all i just reinstalled xp on windows and now i have mpeg 4 and 263xhd files which wont play in my players i have treyd vlc but it flickers bad can any 1 tell me what codec is best to install for these files and when i try to open it in media classi i get
    C:\Documents and Settings\ruby\Desktop\s-300.mkv::Undetermined (Audio 1)
    AC3 Audio Decoder::Out
    AC3Filter::Out
    Audio Switcher::Out
    Media Type 0:
    Audio: PCM 48000Hz stereo 1536Kbps
    AM_MEDIA_TYPE:
    majortype: MEDIATYPE_Audio {73647561-0000-0010-8000-00AA00389B71}
    subtype: MEDIASUBTYPE_PCM {00000001-0000-0010-8000-00AA00389B71}
    formattype: FORMAT_WaveFormatEx {05589F81-C356-11CE-BF01-00AA0055595A}
    bFixedSizeSamples: 1
    bTemporalCompression: 0
    lSampleSize: 1
    cbFormat: 18
    can any 1 help please
    Use Gspot to determine the Codec that is used in your video. You can then load that one. Avoid Codec packs; they can create a lot of problems.
    Jul 2007
    still no go i tryed a few codec but all films play slow stutter and keep getting audio swither any like mostly used codec i can install so most files and these will play whats with this audio switcher cheers
  4. Banned
    Freedonia
    Post here what codec GSpot says it uses. Also post the resolution. You should be aware that any H264/X264 file larger than 1280x720 may be too much for your PC to play back. H264/X264 are really pushing the envelope and they're a little ahead of the home PC technology curve for most people. Probably 5 years from now you'll play them with no problem, but right now playback of these files with resolutions greater than 1280x720 is problematic on a large number of PCs.
    By the way, your audio is PCM, which is WAV format. You don't need anything special for that, so whatever your problem with the file is, it's video related.
    Jul 2007
    mmm i loa it in gspot but nothing on the right hand side info has anything is there a tab or anything i got to click
  6. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    Try MediaInfo, since it seems you have MKV and MP4 files. GSpot's good, but its support for MKV and MP4 files may or may not work for everything. (though I may be wrong)
    peterg60, Do us all a favor and write in complete sentences with periods at the end. It is difficult to read your lazy writing. I see you are in the UK so there are people all around you who can help with the language if you need it. If you make an effort to write so that people can easily read it, more people will help you with your problem.
