Hi.
I have one file, encoded in AVC codec/container.
How can I extract the stream audio from it?
And how can I conververt it to AVI/MP3 files?
Thanks.
devil (johner)
Hi.
Above follows the information about my file:
General #0
Complete name : C:\
Format : MPEG-4
Format/Info : ISO 14496-1 Base Media
Format/Family : MPEG-4
File size : 361 MiB
PlayTime : xh xmn
Bit rate : 393 Kbps
StreamSize : 2.86 MiB
Encoded date : UTC xxxx
Tagged date : UTC xxxx
Video #0
Codec : H.264
Codec/Info : H.264 (3GPP)
PlayTime : xh xmn
Bit rate : 350 Kbps
Width : 608 pixels
Height : 256 pixels
Aspect ratio : 2.35
Frame rate : 25.000 fps
Bits/(Pixel*Frame) : 0.088
StreamSize : 321 MiB
Title : Video
Audio #0
Codec : AAC LC-SBR
Codec/Info : AAC Low Complexity with Spectral Band Replication
PlayTime : xh xmn
Bit rate : 40 Kbps
Bit rate mode : CBR
Channel(s) : 2 channels
Sampling rate : 44 KHz
Resolution : 16 bits
StreamSize : 36.7 MiB
Title : English
Language : English
I wanna demux/convert the audio in MP3 and AVI ( xvid/divx codecs).
Any MORE advices, suggestions and programs that can handle this?super is an easy way to convert to avi with xvid/mp3.
there are better ways of course
Thanks for help.
devil (johner) -
tmpg xpress 4
if the direct show filters are there it will import,
and if you have the vfw and acm codecs you need installed on your machine you can encode with them.
Xpress 4 also has divx built in with profiles and outputs to the divx container, an advanced avi container.
you can frameserve with avisynth.
using directshowsource, or avcsource after running the elementary avc stream through dgavcindex.
the you can use other programs to encode like vdubmod
as long as your video is not vfr it's nothing too taxing
gl
how do you convert .ogg audio file to mp3?
By shun in forum AudioReplies: 5Last Post: 22nd Sep 2023, 15:34 -
FLACK File to MP3 Will Not Convert
By Teac23 in forum AudioReplies: 1Last Post: 12th Jan 2011, 10:32 -
How to convert the 1gb VOB file to 80Mb AVI file ?
By zohaibshaikh in forum Newbie / General discussionsReplies: 3Last Post: 17th Oct 2010, 06:41 -
I want to demux an .mp4 file and convert to a microsoft dv .avi file
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 4Last Post: 13th Sep 2009, 21:42 -
how can I convert dvd file on my computer to avi or a different file
By brew in forum Video ConversionReplies: 3Last Post: 19th Nov 2007, 19:21
