As the title says I've been trying to burn dvds recently and they seem to be failing at around 23%. I cannot pin-point when this began to happen as i have made a few changes recently, one them being that I have upgraded my version of nero to Nero 7 Ultra and i have also changed the dvd media that i use.
Media = SUMVISION RITEK 8X DVD-R
Burner = Pioneer 107d
Programs used = imgburn, nero recode, intervideo dvdcopy5, (all burn with exact same results of about 23% burned to disk and then fail.)
I have tried a couple of things that i found on googlebut none helped: Using nero drivespeed and setting the spindown time to ''infinate''.
Also tried checking the secondary ide channel to see if the transfer mode was set to ''DMA if available'' - it was.
I have burned about 10 coasters and tried another 2 types of dvd media (one of which wouldn't even begin to burn at all) and have now come to a dead end. I have the nero logfile and can post it if that would help.
I would be very grateful for any advice.
Dave.
Results 1 to 9 of 9
The fact that you appear to be having the same issue with multiple burning apps and different media, would lead me to believe you have a hardware issue(bad burner).
Try uninstalling/reinstalling ImgBurn and then try burning a data disc (this will eliminate movie encoding apps/issues).Google is your Friend -
----- Begin NeroAPI error log -----
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=169792 bytes, created 14/03/2007 12:43:16
NT-SPTI used
Nero API version: 7.9.6.0
Using interface version: 7.5.0.1
Installed in: C:\Program Files\Nero\Nero 7\Core\
Application: Ahead\Nero Recode
Internal Version: 7, 9, 6, 0
Recorder: <PIONEER DVD-RW DVR-107D>Version: 1.22 - HA 1 TA 1 - 7.9.6.0
Adapter driver: <IDE> HA 1
Drive buffer : 2000kB
Bus Type : default (0) -> ATAPI, detected: ?
=== Scsi-Device-Map ===
CdRomPeripheral : IVI Virtual CD 0.5a iviVD Port 0 ID 0 DMA: Off
DiskPeripheral : ST3120022A atapi Port 1 ID 0 DMA: On
CdRomPeripheral : JLMS XJ-HD166S atapi Port 1 ID 1 DMA: On
CdRomPeripheral : PIONEER DVD-RW DVR-107D atapi Port 2 ID 0 DMA: On
=== CDRom-Device-Map ===
JLMS XJ-HD166S D: CdRom0
PIONEER DVD-RW DVR-107D E: CdRom1
IVI Virtual CD G: CdRom2
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 1023MB (1048048kB)
Free physical memory: 541MB (554760kB)
Memory in use : 47
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
25.7.2007
NeroAPI
11:57:54 #1 Text 0 File SCSIPTICommands.cpp, Line 424
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
11:57:54 #2 Text 0 File DlgWaitCD.cpp, Line 307
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: -1 ( 0:00.-1, 0MB)
11:57:54 #3 Text 0 File DlgWaitCD.cpp, Line 319
Write in overburning mode: NO
11:57:54 #4 Text 0 File DlgWaitCD.cpp, Line 2964
Recorder: PIONEER DVD-RW DVR-107D, Media type: DVD-R
Disc Manufacturer: RITEKG - 05
Disc Application Code: 64, Disc Physical Code: 193
11:57:54 #5 Text 0 File DlgWaitCD.cpp, Line 493
>>> Protocol of DlgWaitCD activities: <<<
11:57:54 #6 Text 0 File SCSIPTICommands.cpp, Line 215
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
11:57:54 #7 SPTI -1066 File SCSIPassThrough.cpp, Line 179
CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1066)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xAC 00 00 00 00 00 00 00 00 64 00 00
Sense Area: 0x70 00 05 00 00 00 00 0E 00 00 00 00 24
Buffer x091bb4c0: Len x648
11:57:54 #8 Text 0 File BurnAtOnceRecorder.cpp, Line 1028
Estimated filesystem size: 544
11:57:54 #9 Phase 36 File APIProgress.cpp, Line 285
Burn process started at 4x (5,540 KB/s)
12:10:55 #10 Text 0 File BurnAtOnceRecorder.cpp, Line 1727
Buffering files started
12:10:55 #11 Text 0 File BurnAtOnceRecorder.cpp, Line 1433
Buffering VIDEO_TS.VOB
12:10:56 #12 Text 0 File BurnAtOnceRecorder.cpp, Line 2626
Finished buffering file VIDEO_TS.VOB of size 9138176 bytes (4462 sectors)
12:10:56 #13 Text 0 File BurnAtOnceRecorder.cpp, Line 2693
Finished writing file VIDEO_TS.VOB of size 9138176 bytes (4462 sectors)
12:10:56 #14 Text 0 File BurnAtOnceRecorder.cpp, Line 2706
Buffering files finished successfully
12:10:57 #15 SPTI -1066 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x24
Sense Qual: 0x00
Buffer x0495e080: Len x648
12:10:57 #16 Text 0 File DVDR.cpp, Line 3225
Recording mode: Sequential Recording Mode for Multisession
12:10:57 #17 Text 0 File DVDR.cpp, Line 3381
Start write address at LBA 0
DVD high compatibility mode: No
12:10:57 #18 SPTI -1066 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x24
Sense Qual: 0x00
12:10:57 #19 Text 0 File Cdrdrv.cpp, Line 9869
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 0.0 (0)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Revision number of maximum recording speed: 3.0
Revision number of minimum recording speed: 0.0
Revision number table of recording speed: 0.1 0.2 0.3 - - - 0.4
Class: 0
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 30 01 02 04 06 00 00 - 00 08 00 00 00 00 00 00 .0..............
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
12:10:57 #20 Text 0 File BurnAtOnceRecorder.cpp, Line 689
Reserved fragment at 0. Length: 5056
12:10:57 #21 Text 0 File BurnAtOnceRecorder.cpp, Line 1910
Reserved start fragment at 0
12:10:57 #22 Text 0 File BurnAtOnceRecorder.cpp, Line 689
Reserved fragment at 5056. Length: 64
12:10:57 #23 Text 0 File BurnAtOnceRecorder.cpp, Line 1427
Writing VTS_01_1.VOB at sector 5120
12:13:01 #24 SPTI -1106 File SCSIPassThrough.cpp, Line 179
CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1106)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x73
Sense Qual: 0x03
CDB Data: 0x2A 00 00 05 03 10 00 00 20 00 00 00
Sense Area: 0x71 00 03 00 00 00 00 0E 00 00 00 00 73 03
Buffer x093bb4c0: Len x10000
0x00 00 01 BA 45 24 84 69 25 57 01 89 C3 F8 00 00
0x01 E0 07 EC 81 00 00 E5 04 26 C8 80 DD 75 43 52
0xA7 C7 C8 4C 02 BD 96 7D 41 A1 86 D2 51 0D 9B 5F
12:13:01 #25 Text 0 File BurnAtOnceRecorder.cpp, Line 2236
Failed to write 48 sectors at 328464
12:13:01 #26 Phase 179 File APIProgress.cpp, Line 285
Writing file to disc failed
12:13:05 #27 Text 0 File BurnAtOnceRecorder.cpp, Line 3710
Disc info:
Partitions: 2
#0: Start: 0, Size: 5040
#1: Start: 5056, Size: 48
12:13:05 #28 Text 0 File SCSIPTICommands.cpp, Line 261
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
12:13:05 #29 Text 0 File SCSIPTICommands.cpp, Line 424
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
12:13:05 #30 Text 0 File Cdrdrv.cpp, Line 11185
DriveLocker: UnLockVolume completed
12:13:10 #31 Phase 38 File APIProgress.cpp, Line 285
Burn process failed at 4x (5,540 KB/s)
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=9464 bytes, created 08/03/2007 00:51:00
File 'Drivers\PXHELP20.SYS': Ver=3.00.56a, size=43528 bytes, created 08/03/2007 00:51:00 (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
----- End NeroAPI error log -----
12:13:10 File burn_dvdfiles.cpp, Line 308
Compile DVD: exit -
The drive is a bit old (firmware) and Ritek media is questionable. Have you tried burning at 2.4x or 4x?
Solved the problem very simply by using the 'Nero clean tool' to remove 'Nero 7' (Garbage) from my comp and re-installed Nero 6.6. Seems to burning dvds now without a problem.
Sorry for wasting everyones time. -
The only problem is the RITEK media - they are crap and a waste too.
*** Now that you have read me, do some other things. ***
Megui encoding stops
By sanosuke in forum Video ConversionReplies: 1Last Post: 20th Dec 2012, 21:36 -
MKV stops
By kcmccombs in forum Newbie / General discussionsReplies: 1Last Post: 18th Jul 2011, 22:17 -
ImgBurn stops part way thru burning
By audax in forum Authoring (DVD)Replies: 2Last Post: 27th Jul 2009, 06:17 -
Burner stops while burning DVDs
By standalone in forum Authoring (DVD)Replies: 9Last Post: 20th Sep 2007, 23:48
