    Dec 2006
    Asian heart
    Hi all pros! I'm a newbie! I got the problem! so I need your help,please!!!
    I use VirtualDubMod to re-encode and resize video files. AVI with the info:
    to play on mobile (nokia 6681) with SmartMovie. After re-encoding, here the new ones info:
    This kind of .Avi files with audio format :AC3-ACM can't played with SmartMovie?
    Then, I've already tried again and again with the new filter AC3-ACM de-compressor v1.31 https://www.videohelp.com/tools/AC3_ACM_Decompressor but got the same results!
    When played on mobile, there is no audio!
    Any reply is highly appreciated! thanks a lot!
    Dec 2004
    Australia
    Set the audio to full processing and convert to mp3 (may not to install LAME ACM), that is assuming that SmartMovie supports mp3. AC3-ACM will do the decoding.
    Dec 2006
    Asian heart
    Yeah!Thanks,Man! I will try!And, I also got the solution with the great BATCH AVI_GAIN_V05! Anyone get the same problem with MP3---AC3 can try that!You can read it more,here: in our 4rum Good luck to all!
