hi i use nero 7 the latest to convert films but on some of the films if you play them through nero showtime they are out of sync and if you convert them with nero they also come out of sync
but if you use tmpgenc they come out in sync
any help much appreciated?
Nero isn't a very good encoder, it often has sync problems, especially if the source has VBR MP3 audio, but often even if it doesn't. Personally I wouldn't use it for encoding at all, and would even question it's use for anything else when better tools abound for free.
Because you have put this under Authoring, I'll assume you are converting avi files to DVD, in which case should also consider
ConvertXtoDVD (not free, but more reliable than Nero)
DVD Flick (Free)
FAVC (Free) - both of these use much better encoders than ConvertXtoDVD or Nero, however it comes at the cost of speed.Read my blog here.
autoGK started encoding out of sync
By octeuron in forum Newbie / General discussionsReplies: 7Last Post: 8th Jul 2010, 15:19 -
Out of sync issues after encoding and muxing?
By mrjust in forum Newbie / General discussionsReplies: 3Last Post: 27th Mar 2010, 17:06 -
Audio out of sync half way through encoding
By gertielongbum in forum Newbie / General discussionsReplies: 2Last Post: 12th Jan 2009, 13:59 -
Encoding yields audio out of sync
By chrisr34000 in forum Video ConversionReplies: 3Last Post: 2nd Jun 2008, 06:21 -
Sync issues with encoding for DVD or Web
By sfischer in forum MacReplies: 2Last Post: 26th Dec 2007, 19:01
