Hi there, i have spent quite a bit of time reading these forums and have decide to finally register !!!
The problem i am having is i am using a Highlander dvd recorder to record televison programs and then wanting to edit them on my pc, i have tryed Tmpenc dvd author and whilst it is a great program to use the output picture is very choppy and terrible quality, i was wondering if what is the best program or way to cut out commercials, add menus, etc without having to re encode the whole thing at the end thus losing all the picture quality ? or is there a better way of encoding so i dont lose the quality ?i have tryed womble as well but it doesnt seem to want to open up the source file, i am usig dvdfab to rip the dvd vr to my hard drive. any help much appreceiated !!!!
Results 1 to 12 of 12
I use Womble to edit the recordings from my Pioneer. It has no problems doing the basic trimming and commercial removal I need to do, and doesn't re-encode. I burn to DVD-RW, and use VOB2MPG to extract the titles for editing. I also use Womble to edit the programme streams I grab from OTA digital broadcasts.
I author with DLP, although the DVD version of Womble does basic authoring. GUIForDVDAuthor is free and can do pretty much anything you will need.
The only way to avoid re-encoding is to make sure what you have fits on a disc. If it doesn't then you have no choice but to either trim it down or re-encode. I record at a setting that puts 95 minutes to a single layer DVD. After commercial removal I get two standard length episodes per disc.
If you do have to re-encode, use a good quality encoder. HCEnc is free and very good, as is Quenc.
I don't know what your problem is with Womble - I have had no issues with it - however if you are just doing basic trimming, VideoRedo is worth a look. It is very similar to Virtualdub or AVI Demux in feel. If it has issues with your source then I would look seriously at what DVD Fab is doing.Read my blog here.
Thanks for the reply, very helpful ! the problem i find with womble is it wont oen up the whole dvd as one file, it is seperated into 3 files vob 1, vob 2, vob 3, is this normal ? thanks again !
Thanks again for the reply, every time i try to extract the files using vob2mpg it will only extract 1 vob file when there is 3, thus creating one mpg file which is only a third of the complete movie, i have tryed using dvd decrypter as well ripping it as an ifo and it gets to 40% and says cylinder redundency error or something along those lines, thanks for the help !
VideoReDo plus does a great job.
No quality loss, as it doesn't re-encode.
Frame accurate editing to get rid of those nasty commercials.
also does stream repairs to maintain lipsync etc.
outputs a mpeg2 file, just need to author it to DVD, i use "TSUNAMI-MPEG DVD Author PRO"
Oh Yeah!......easy to use. -
Thankyou for all the help guys !!!!!!!, it has helped me out big time and i am on my way to making my first edited video !!
Just a quick question, im having trouble authoring in TSUNAMI-MPEG DVD Author PRO, does this re-encode the file or just straight burn it ? how do i just author it whithout having to re-encode, and can videredo do this authoring ? do you know of the basic steps to author using this program as i am very new at this. thanks again for the help !Originally Posted by darkknight145
Oh ok doing a couple of test runs now, thanks for the help !!!!Originally Posted by guns1inger
Best quality DVD output software for maintaining photo quality
By P_Erickson in forum Newbie / General discussionsReplies: 20Last Post: 21st Apr 2012, 23:30 -
FFmpeg and quality of the output video
By Vidameker in forum Video ConversionReplies: 2Last Post: 26th Jan 2010, 21:46 -
Output quality
By The Mighty Boosh in forum EditingReplies: 1Last Post: 15th Jun 2009, 21:11 -
Will there be a difference in output quality?
By ingeborgdot in forum EditingReplies: 55Last Post: 21st Sep 2008, 19:41 -
Output quality and settings of DVDShrink
By src2206 in forum DVD RippingReplies: 21Last Post: 23rd Jan 2008, 07:38
