Download and install the free VMWare server, create a new system, install NT/Win2K/XP (if you have an older copy) or linux (free) on it, install the printer to that system using a virtual port, share it out, add the shared printer to Vista, and print to it when needed.
It's a long and free way around using your old printer until you can get something more recent.
Results 31 to 36 of 36
theHTPC.net
Find a cure for cancer by folding proteins! Join the Team 32 Folding@Home project (#3 worldwide!). Check us out here -
My old HP printer turned out to be a 950C
, which installed with no problem, but I did have to use a rear USB port. Apparently with USB printers, Vista does the install automatically. If your printer has a parallel cable capability, and you have a cable handy, you might try that as that doesn't seem to be automatic. I'm encoding two Xvids at the same time with the computer at present, so access is somewhat limited. I'll check it when they finish.
Way to go, give the guy the benefit of the doubt. I'm a student and have Vista too at an extremely reduced price. I "acquired" it and didn't pay a single dime.Originally Posted by buttzilla
It's doing a lot of good though sitting on my shelf, as it broke a couple weeks after installing it. Didn't see my old HP scanner either. Was just testing it out though so I gave up on it and went back to Linux.
Hunting, sure i'll go hunting. When is cow season? -
cant use parallel cable, its a laptop with USB only.
also vista wont even print through the printer if it is shared, i tried to while it was connect to my XP computer and all it can say is driver install failed -
Looks like you've reached a dead end here.
Better to ask at a more appropriate forum.
The usenet group news://comp.periphs.printers would be your best bet, available on Google at http://groups.google.com/groups?&group=comp.periphs.printers if you don't have usenet access.
You need to register with Google to make posts. -
This is a great idea. I just did this with MS Virtual PC 2007. I installed W2K + all SP and through this emulated environment i was able to use a parallel printer (for test) and a serial port Minidisc controller that came with my MDS-PC2.Originally Posted by jkleslie
VISTA Printer Always "Offline"
By PC2K1 in forum ComputerReplies: 2Last Post: 5th Jun 2009, 15:16 -
Windows Vista XP 64 bit Oh, my. Printer doesn't work!
By orfajackson in forum Newbie / General discussionsReplies: 6Last Post: 21st May 2009, 00:27 -
How do I share printer on home network in Vista?
By LoveMyslf in forum ComputerReplies: 2Last Post: 10th Apr 2008, 13:08 -
Where to download h263 and older indeo codecs for vista?
By yoda313 in forum Software PlayingReplies: 8Last Post: 12th Sep 2007, 01:03 -
Would an older capture card work on a Vista PC?
By Rein Engel in forum Capturing and VCRReplies: 15Last Post: 23rd Jun 2007, 12:33
