    Jun 2005
    BC, Canada
    Hi there,
    I think I might have possibly found a bug, here are the stepts to replicate it:
    1. Add multiple assets
    2. Choose QuickDVD & Burn
    3. Say no to continue with "QuickDVD"?
    4. Then when done go to the menu
    Then as a result you should see a screen similar to the screenshot below and the only way to get anywhere is to exit and restart SVCD2DVD.
    RGDS
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Ok - thanks for the heads up. I have fix this readu for the next release.
