    Jul 2007
    Is it possible to create an HD dvd from a regular dvd? Can i just get a regular dvd and upscale it? Are their any programs that do this?
    I know i could just get an upscale dvd player, but I just want to be able to play it from my hard drive.
    Thanks.
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Thanks.
    Your display card has an upscale function called "Full Screen". Quality varies by card.
    Software upscale will create long renders and huge files but not much improvement in quality.
    Jul 2007
    I have the "Full Screen" setup in the catalyst control panel.
    Is this the same as a upscaling dvd player?
  4. Member edDV's Avatar
    Mar 2004
    "Full Screen" is usually and option under view in your software video player menu. Yes it is scaling 720x480 or whatever the real resolution to the resolution of your desktop (e.g. 1280x1024). The picture is effectively stretched to fit. The player is supposed to manage aspect ratio and will add letterbox for 16:9 on a 4:3 display.
    Some software upscaling adds some image processing but don't expect miracles. As for viewing on a typical computer monitor, expect similar results. Try a clip both ways.
