I'm new to converting DVDs to AVI files. I have just tried AutoGK v2.40, but I'm having a problem with creating a separate subtitle, as I don't want permanent subtitles in the video.
I used the DVDFAB decrypter to rip the DVD to hard drive. I then started the AutoGK. In the subtitle box, I selected the language, which is English wide. In the advanced setting, external subtitles button is selected. However, when I used Media Player Classic to play the AVI file, there were two overlapping subtitles in video. If I do not select any subtitles in the mainscreen with advanced settings set to the external subtitles, then there are no subtitles in the video, and there is no subtitle file created.
I followed the AutoGK guide, but I don't know what I did wrong. Any help would be greatly appreciated.
Two subtitles is generally the result of two subtitle renders. In this case that would probably be MPC's internal renderer and ffdshow or DVobSub. Also possible that you have hard encoded subs and one renderer. You can check by opening the video in VDub. If there are no subs displayed, then there are non hard encoded.
You are right. One of the subtitles is hardcoded in the video. What puzzles me is that I followed the procedure online in the autoGK guide for creating a separate subtitle file. Could anyone tell me if there is any trick in using autoGK to create a separate subtitle file?
Thanks -
Since the guru said there was no trick, I decided to try it myself. The only difference this time is that I reload the input file in the AutoGK after I selected the external subtitle in the advanced setting. This seems to do the trick. I only have the external subtitles now. Thanks a lot for your help.
However, the subtitle is automatically displayed in my MLC when I load the file to play. How do I disable the auto loading of subtitles?
Subtitles: diferent fonts, separate files, interpretable by DVD player
By Ze Tomes in forum SubtitleReplies: 17Last Post: 13th Jul 2010, 20:29 -
Merging Video Segments with Separate Subtitles
By thomasj in forum Authoring (DVD)Replies: 2Last Post: 24th Apr 2010, 07:40 -
autogk subtitles
By surfer in forum DVD RippingReplies: 10Last Post: 4th Apr 2008, 12:39 -
QT file w/subtitles separate - VLC - how to combine to Toast
By BattyRoy in forum MacReplies: 8Last Post: 20th Jan 2008, 15:07 -
No subtitles with the AutoGK
By wvpneto in forum SubtitleReplies: 5Last Post: 11th Jun 2007, 23:54
