thanks for any help on this question in advance
i am not you am not i am not you am not i am not you am not i am not you am not i am not you.
There are numerous programs out there that can convert these types of files. Goldwave, is an example (where you would open up the mp3 in the program and then "save as" a .wav).
I don't know why you want to do this, but keep in mind that this will not improve the quality of the sound from the .mp3, since once it has been compressed to whatever level your .mp3 is encoded at, uncompressing it to a .wav won't restore the original uncompressed digital audio data. -
thanks to the both of you. the answer to your question- i know it's ridiculous to change mp3s to wavs- is in editing cutting and joining where you'll find me whining about why cut assistant can't work with virtualdubmod, which is the divx cutter that can cut with mp3, so i have to revert to virtualdub...Originally Posted by Rich86
anyway, thanks, and i think this is the only thing i can do.i am not you am not i am not you am not i am not you am not i am not you am not i am not you. -
WinLame (frontend for high quality mp3/mp2 decoder to wav; Lame encoder to mp3):
http://winlame.sourceforge.net/
DVD to WAV/MP3
By Baldrick in forum AudioReplies: 38Last Post: 10th Oct 2020, 04:47 -
after effects mp3 or WAV
By thecrock in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2010, 14:51 -
MP3 or WAV?
By Charmer in forum AudioReplies: 4Last Post: 6th Aug 2009, 19:20 -
mp3 to wav
By stewart2000 in forum AudioReplies: 8Last Post: 27th Sep 2008, 06:12 -
Converting WAV to MP3
By igorek in forum AudioReplies: 5Last Post: 1st Jun 2008, 21:25
