Hello,
i hope this wasn't discussed before but i couldn't find an answer through the search.
How (if possible at all) can i re-encode the video track of Quicktime movies without touching the audio of it. Or the other way round, i.e. re-encode the audio without touching the video track?
I'm looking for something similar to VirtualDub's "Direct Stream Copy" but for Quicktimes.
Thanks in advance![]()
PS: please no suggestions like "convert to Divx" etc.
Files have to stay Quicktime.
thanks.
Could you be a little more specific?
Maybe i'm to dumb but I can't find any settings similar to virtualDub's Direct Stream Copy in QTPro, neither in video settings nor in audio settings. -
thanks.
I've never actually done it myself, however, Quicktime Pro is the only tool that I know of that can work with quicktime files AND output in quicktime format. There are other tools that convert quicktime to avi, mpeg, etc, but nothing else that I've seen that can edit and output in mov.
Try the support and/or forums over at quicktime.comGoogle is your Friend -
(Assuming you're using QTPro):
Open source file.
Disable soundtrack (leaving only video track enabled).
Export to new codec/size/settings.
Close source file WITHOUT SAVING.
Open original source file again.
This time, disable video track (leaving only soundtrack enabled).
[Select All] and [Copy].
Open exported (video only) file.
[Add] (not Paste).
Then [SaveAs], using a different name than the exported file and flattening (aka, do not make a "reference" movie).
DONE. Close out all open files without saving. Delete what you don't want to keep (intermediate exported video file?).
...there are probably quicker ways, but that's foolproof...
Scott -
thank you veeeeeeryyyyy much!
This is what i was looking for for "ages"
First i didn't exactly know what you meant with "Disable soundtrack (leaving only video track enabled)" because i couldn't find that option in the Export or Save settings where there are no options for "direct stream copying" audio or video tracks.
Until i discovered that this has to be done under "window -> show movie properties".
Which never had come into my mind at all before.
Vegas 11, multicamera track only rendering to one video track
By CursedLemon in forum EditingReplies: 0Last Post: 29th Feb 2012, 04:11 -
Audio track shorter than video track in MPEG Video Wizard DVD?
By xxxyyy in forum EditingReplies: 3Last Post: 30th Jan 2011, 14:24 -
Get audio track from DVD Extra instead of film sound track in VIDEO TS
By Josephine in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2010, 13:25 -
How to select audio track opening multi-track container in avisynth?
By lovyagin in forum Video ConversionReplies: 7Last Post: 23rd Sep 2009, 13:16 -
need to substitute spanish audio track with english track
By rebeltaz in forum AudioReplies: 5Last Post: 26th Dec 2007, 20:12
