In the settings it only allows me to link it to virtualdub, asfbin, avidemux, mp4box, so i'm doomed because only virtualdubmod apparently tolerates both cut assistant, xvids etc and mp3s. Do I now have to learn how to adapt mp3s to WAV extensions because cut assistant forces me to work with virtualdub or is there another cut assistant out there than can tolerate virtualdubmod?
oh and the reason i have to use cut assistant is cuz for some reason no virtualdubmod i know can allow you to edit (or in fact no virtualdub since the screen goes black and you can't see anything. If it's the only alternative, could someone show me how to change mp3s to wavs?
i am not you am not i am not you am not i am not you am not i am not you am not i am not you.
Originally Posted by celtic_druidi am not you am not i am not you am not i am not you am not i am not you am not i am not you.
Originally Posted by pondleaping
Didn't try it myself, though.
Hope that helps...
Cut Assistant not working the way it's supposed to
By jeanmarc in forum EditingReplies: 3Last Post: 3rd Dec 2010, 04:47 -
HP Product Assistant
By jyeh74 in forum ComputerReplies: 1Last Post: 3rd Jul 2009, 18:17 -
automatic or batch processing in Cut Assistant: possible?
By cbarduck in forum EditingReplies: 0Last Post: 9th Feb 2009, 06:11 -
Can remote assistant work between XP and Vista?
By yoda313 in forum ComputerReplies: 6Last Post: 7th Jan 2009, 17:53 -
two problems with virtualdub1.71 and its cut assistant
By pondleaping in forum EditingReplies: 7Last Post: 7th Jul 2007, 12:42
