I want to capture video from my tv-card (PAL 720x576)...to be displayed in the end on a beamer with 800x600 or 1024x768.
Now in what resoltion should i capture:
720x576 or
800x600 or
1024x768
To get the best results?
Also which codec/format should i use to save my uncompressed (Huffyuv) videos to? I tried WMV, nice filesize, but the video has no smoothness.
Your best bet would be 720 x 576 and use mpeg2 at a bit rate of around 8000kbs. This is DVD compliant resolution so just do everything as if you are capturing to turn it into a DVD (even if you aren't because you may want to at some time in the future).
Your capture software may even have a predefined template for PAL DVD.
what resolution will a DVD recorder set-top capture.
By xbill in forum DVD & Blu-ray RecordersReplies: 6Last Post: 11th Jan 2012, 15:40 -
videocast osprey capture resolution
By jaybird in forum Capturing and VCRReplies: 0Last Post: 27th Apr 2009, 22:29 -
Force custom resolution for TV out in CLONE mode for DV Capture ?
By TheParadoX in forum Capturing and VCRReplies: 4Last Post: 6th Oct 2008, 19:00 -
tv tuner/analog capture resolution problem
By cooldude859 in forum Capturing and VCRReplies: 4Last Post: 13th Dec 2007, 01:16 -
Capture Hi8 using what resolution?
By chrishallowell in forum Capturing and VCRReplies: 2Last Post: 3rd Oct 2007, 11:57
