Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
  1. Member joelson's Avatar
    May 2004
    Brazil
    Hi All!
    I have captured a video from an old VHS tape. I'm using Pinnacle AV/DV to capture.
    I think the colors are kind of lighter. The VCR output connects to a PAL-M/NTSC transcoder. Do you think the video may lose quality by using the transcoder?
    Is there a way to improve the capture quality while capturing?
    Thanks in advance!
    Best regards,
    Joelson.
  2. Member Marvingj's Avatar
    Apr 2004
    Death Valley, Bomb-Bay
    Get a color corrector...It will adjust the colors, the more expensive ones can adjust the black level.
    http://www.absolutevisionvideo.com
    BLUE SKY, BLACK DEATH!!
  3. Member joelson's Avatar
    May 2004
    Brazil
    Is this color corrector a hardware? Or a software?
    Is it done during or after the capture?
    Best regards,
    Joelson.
