I re-authored a music DVD. I demuxed the DVD with the program that saves the chapters in frames. However, the DVD Authoring program I'm using wants to have the chapter timings and not the frames.
So my question is: how to convert those chapters which are in frames to chapter timings?
Or are there any demuxing programs that would give the chapter timings right away when you've demuxed a DVD?
Thx in advance!
Since you are in Finland, I assume you are using PAL.
To convert a duration in frames to seconds, simply divide your frame values by 25. (If you are using a different frame rate, e.g., 24fps, then divide by that instead).
If you are using NTSC, then it can get rather complicated depending on whether the durations use drop-frame numbering or not. -
Yep, I'm using PAL.Originally Posted by JohnnyMalaria
And thanks for the help!
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 22:33 -
simple photoshop edits to selected frames (photoshopping time code away)
By Spiny Norman in forum EditingReplies: 8Last Post: 27th Jul 2011, 12:57 -
resetting time codes on chapters using vob2mpg pro
By sbruck in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 1st Oct 2009, 15:53 -
Pinnacle Dazzle to watch a camera in real time and to grab frames
By quartet401 in forum Newbie / General discussionsReplies: 0Last Post: 29th Jun 2009, 17:03 -
what is the 'DSL' file that seems to appear from time to time on DVD's?
By rotuts in forum MacReplies: 6Last Post: 24th Aug 2008, 14:08
