Results 1 to 10 of 10
  1. Hi I have a DVD with vob files etc but need a program to add chapters so it can be read in dvd-shrink using re-author
    any suggestions
  2. There may be occasions where you may want to add a chapter marker to a movie. This will most likely involve splitting a cell, since chapters can only begin on new cells.
    The easy way to do this is with VobBlanker.
    http://jsoto.posunplugged.com/guides/VobBlanker/splitting_cells/index.htm
  3. Isnt there anything easier as this looks well hard I am not very good at all this
    Apr 2004
    Miskatonic U
    You don't need chapters for Shrink to be able to read it. You do need a valid DVD structure, including IFO files. These can be created with IFOEdit.
    Read my blog here.
  5. Originally Posted by guns1inger
    I have created IFO Files with IFOedit but when I try re-author with dvdshrink it dont show as I believe it needs the chapters added
  6. guns1inger did u see my reply as still stuck on this
    Apr 2004
    Miskatonic U
    Shrink does not need chapters. It does need valid IFO files, and depending on the state of the VOBs, even IFOEdit might not be able to create them.
    Where did these VOBs come from that they don't have the other required files ?
    Simplest solution, seeing you were going to re-author anyway, would be to use VOB2MPG to get the titles out of the VOBs, then re-author using GUIForDVDAuthor to create a usable disc.
    Read my blog here.
  8. ok many thanks for this info
  9. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Ignore the spammer.
    @allsmaile - go peddle your wares elsewhere
    Read my blog here.
  10. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Did you press the "Get VTS Sectors" button and then save the IFOs once IFOEdit was done ? This is a fairly common oversight when using IFOEdit to recreate IFOs is all.
    Here's the guide:
    http://members.dodo.com.au/~jimmalenko/test.htm#ifoedit
    If in doubt, Google it.
