Hey guys, I've looked for help on this topic through the board and couldn't seem to find an answer, so I thought I would ask some of you because I know a lot of you know a lot of capturing video/audio.
Basically I'm trying to capture some video game footage of me playing in VirtualDub, and I can record video/audio files just fine, however whenever I select the "enable audio playback" and set the audio device as my Capture Card (Dazzle DVD Recorder), the video immediately becomes choppy and almost unplayable.
Does anyone know what is causing this issue, or how to fix it? I seem to be able to record in Studio 10 just fine without the choppy audio (however Studio 10 kind of sucks and I can barely see the game in such a tiny window). Any suggestions on what it might be? Thanks in advance for the help, I really appreciate it.
What , what ?
You shouldnt set the audio playback device as the capture device ... and you wonder why it gets choppy .
Your pc's audio hardware is the default audio playback device ... the dazzle device is only INPUT , not OUTPUT .
To stop audio being heard , you should disconnect from from capture device ... stop the software and close it .
If you had connected the audio to pc linein for capture , you only need to disable it in the audio properties dialog , during playback of the recorded clip , in order not to hear what is on the audio input device .
If you have a pass-through cable , as some capture devices come with these ... throw it in the bin and forget it .
Choppy video playback.
By Stealth3si in forum Media Center PC / MediaCentersReplies: 5Last Post: 2nd May 2014, 02:16 -
Samsung BD-P1600 enabling video playback from data discs and usb devices.
By Jeroth in forum DVD & Blu-ray PlayersReplies: 4Last Post: 9th Mar 2010, 15:47 -
By dexter30 in forum Newbie / General discussionsReplies: 13Last Post: 6th Nov 2008, 13:10 -
choppy video playback
By RobotFood in forum Video ConversionReplies: 9Last Post: 15th Jul 2008, 08:40 -
TS audio playback is choppy
By autumnwillow in forum Newbie / General discussionsReplies: 5Last Post: 12th Nov 2007, 10:14
