I'm using ATI AIW Pro 128 32MB graphic card and MCC 6.3. I connect my Sony HandyCam (analog vedio camcorder) using composit cable. I can play and record both video and audio. When I run VirtualDub 1.4.8, click Capture AVI menu item to display capture mod window, then play my camcorder, the capture mode window displays the video, but no sound. If I start capture a piece of video to an AVI file, the AVI file can be played in MediaPlayer, but no sound.
When I play and record my video, the Mute checkbox in all playback volume are uncheck and the slider is set to maximum, the Line In volume in Recording volume is selected.
Does any one have idea how to solve the problem?
Kinlun Yu
I faced the similar problem with VirtualDub 1.4.8. It gives me some sort of error "Audio not captured, Check Sound card" and some message with "AVIOutput()" on it .
Earlier VirtualDub versions captured without any problems.
AVI_IO captures without any problems.
Any one else facing a similar problem with VirtualDub 1.4.8?
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 22:03 -
3d video with dts sound how to convert to ac3 sound
By fredddiemercury in forum Video ConversionReplies: 4Last Post: 2nd Nov 2011, 15:54 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 15:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 12:58 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 19:01
