hi i want to convert .hddvd.x264. to mpeg4 to play on my ps3 or wmv without losing quailty to use on 360 i just have fresh installed window and all my codec are gone now i have3 tryed ps3 video 9 but i lose quality and when i try ps3 converter 3 it fails as soons i put in mkv file in it .
it didnt did this before maybe i havent installed the right codec or am missing some can any 1 help me so when i have got hd mkv file to convert to mpeg4 without loss of quatily and what is the best or right codec to install for ps3 coverter 3
thanks![]()
Welcome to VideoHelp. To get the most out of this place, please take your time and read our rules!
Among those you'll find:
/MatsPlease try not to "bump" your topic.
Replying to your own topic to get it to the top is annoying. Try to have some patience, this is a bulletin board, not IRC. It may take some time (e.g., one or two days) before someone can answer your query or question. -
I suggest going to the forums at http://www.doom9.net. One of the forums there has an ongoing discussion about converting HD-DVD rips to WMV. It's fairly complicated and if you are a newbie, it may not be very easy for you. If you are looking for a one click solution, at this time there isn't one.
thanks for the help been on doom site and im am currently changing container to mp4 witout encoding cheers
Keep in mind that they both only support upto HP 4.1 so the file may not play. Also I believe that they only support 2 channel audio for mp4.
Converting DV to interlaced x264
By mokalan in forum Video ConversionReplies: 2Last Post: 7th May 2012, 17:12 -
Converting x264 to .avi?
By Hank Kinsley in forum Video ConversionReplies: 2Last Post: 24th May 2010, 18:31 -
Converting HDdvd o Blu-ray... Testing... Newbie !!!
By kulmagen in forum DVD RippingReplies: 3Last Post: 11th Feb 2008, 15:13 -
x264 to HDDVD
By davie89 in forum Authoring (DVD)Replies: 1Last Post: 22nd Nov 2007, 04:08 -
HDDVD/BluRay and x264+Matroska?
By BIOHazard87 in forum Newbie / General discussionsReplies: 10Last Post: 3rd Nov 2007, 04:41
