For the last month, I've been having problems with my Sound Blaster sound card, the system detects the card but it doesn't load the drivers, and on the device manager list, i see a problem with the kerrnel sound device showing the following problem:
Can anybody help me out on this?Windows cannot load the device driver for this hardware because there is a duplicate device already running in the system. (Code 42)
	Try moving it to another PCI slot, but avoid the one under the video card if possible. It usually shares IRQs (Interrupt ReQuest lines) with other devices. Your device manager should show if there is a conflict. You could also assign IRQs in BIOS, but most motherboards are set up to do this automatically.
 Here's a article that may help if IRQs are your problem. Usually moving the cards around solves most of it: http://www.helpwithpcs.com/upgrading/change-irq-settings.htm
 Also, if you have a on-board audio card, disable it in BIOS if you aren't using it.
  each audio track on different audio channel or deviceBy mikedepetris in forum Software PlayingReplies: 2Last Post: 28th Nov 2009, 09:56
  HD Pvr 1212 - device is not connected - can't use device in arcsoft softwarBy yoda313 in forum Capturing and VCRReplies: 9Last Post: 16th Aug 2009, 18:22
  Default Audio Device in VLCBy EliteMarine in forum AudioReplies: 3Last Post: 14th Jan 2008, 21:44
  no audio device after uninstalling antivirus?By Rudyard in forum ComputerReplies: 4Last Post: 23rd May 2007, 22:19
  win xp audio deviceBy dvds2u in forum ComputerReplies: 8Last Post: 15th May 2007, 16:03
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
