Hi,
I have tried AVI2DVD to convert AVI to MPG, at least this is what I want.
I am using HCenc but when the conversion is finished the MPG is not there but instead VOB files.
I can see that a MPG is generated during the conversion but in the end it is not present anymore.
Is there any way to keep the MPG when using HCenc in AVI2DVD??
Exactly! It's not hard. Download avisynth and fitcd (to create a simple avisynth script). Load the avs into hc. Set bitrate, aspect ratio, Encode away. Resulting file is video only m2v. Process audio seperately.Originally Posted by redwudz
CLICK HERE for a guide.Donadagohvi (Cherokee for "Until we meet again") -
Yea do it manually. Use fitcd for the avisynth script or use notepad or avsp to produce it yourself....and feed it to hcenc for the video. And use a separate standalone audio encoder like besweet or aften for the audio. And mux the streams using mpegvcr, mpeg video wizard, tmpgenc, bbmpeg, etc.Originally Posted by blizzery
or
FAVC has an option to "keep working files" and you can use a muxer to mux video(.m2v) and audio(.ac3) into an mpeg file for the files in the working folder.
I dunno if avi2dvd has this option like favc though.
HCenc and PanScan
By Comp360 in forum Video ConversionReplies: 2Last Post: 14th Mar 2011, 18:35 -
Problem with HCenc 0.24.
By HolyFries in forum Video ConversionReplies: 2Last Post: 17th Jun 2010, 19:03 -
HCenc Question
By Maikeru-sama in forum Video ConversionReplies: 6Last Post: 18th Aug 2008, 13:01 -
Why is my HCenc resulting lighter/brighter AVI video?
By oavs in forum Video ConversionReplies: 16Last Post: 15th Jul 2007, 08:23 -
HCEnc
By Belfour in forum DVD RippingReplies: 1Last Post: 28th Jun 2007, 10:57
