I'm searching for a guide for converting .avi to anything iMovie compatible. I've tried ffmpegx, but can't figure out how to make it work. In the past I've simply used handbrake to rip VOB files into mpeg, however this time I have a data dvd with a 1.3gb avi file that I need to edit in iMovie (which won't even take the file because of the size, it says I need to cut it up by using Quicktime Pro, of course the .avi won't even open in Quicktime). Can anyone help me with this? I did do a forum search but didn't see anything (perhaps I didn't go far enough back). I'd really appreciate it if someone could explain the ins and outs of ffmpegx for me. Thanks!
	MPEG Streamclip and choose File>Export to DV... this file will be imported by iMovie.
 http://www.squared5.com/svideo/mpeg-streamclip-mac.html
 You will also need Perian to open the .avi in QuickTime-based video programs.
 http://perian.org/
	Perian is fine but be sure to update to v1.0 if you've updated your QuickTime to v7.2.
 MPEG Streamclip is wonderful. I wouldn't be without it.
	umm, I'd like to hear what Problems Perian causes unSOUND?
 It does replace a lot of codecs, could you perhaps be having
 a codec conflict in your system with DIVX, ogg, or somesuch?
 Perian v. 1.0 is pretty stable for me, and aside from
 an occasional hiccup, Perian v1.0 is handling 99% of
 my playback/conversion work ( Flip4Mac gets the other 1%).
 And yes, something really went astray with QT 7.2,
 I went back to 7.16 at home."Everyone has to learn, so that they can one day teach."
 When I'm not here, Where can I be found?
 Urban Mac User
  From Vegas to iMovie - Does the version of iMovie matter?By and in forum EditingReplies: 4Last Post: 11th Dec 2011, 21:05
  MPEG4 Possible iMovie Compatibility?By EpicHorse in forum MacReplies: 6Last Post: 18th Feb 2010, 09:42
  Convert from VIDEO_TS to iMovie compatible formatBy Video Star_2 in forum MacReplies: 4Last Post: 11th Apr 2008, 13:53
  MPEG2 to MPEG4 for iMovie editing on a MACBy AAL333 in forum Newbie / General discussionsReplies: 0Last Post: 5th Aug 2007, 00:01
  iMovie converting 16:9 DV-AVI and DV Tape to 4:3 *.dv files.By Cyrax9 in forum MacReplies: 4Last Post: 20th May 2007, 04:41
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Visit Homepage
				Visit Homepage
