I am thinking about purchasing two Philips SPD2413BD internal DVD+/-RW/RDL drives for a few reasons. Mainly so I don't have to worry about the five-time limit and can have drive D as Region 1 and E as Region 2. The next advantage for me is that I can make direct copies without taking extra time to first copy to the hard drive. My problem is if I want to reauthor a DVD using DVD Shrink, (particularly to remove its menus so my carousel changers will switch DVDs automaticly), how can I make DVD Shrink copy my reauthored DVD in drive D directly to a blank DVD+RDL in drive E? Using DVD Shrink, I already tried going from the hard drive to my DVD drive using Roxeo's Drag to Disc Version 6, and the disc didn't play in my DVD player. Is there either a free alternative to DVD Shrink that will allow me to reauthor a source DVD and copy it directly to a target DVD, or a free software that runs in the background that can allow NTFS files to be converted to the DVD standard as DVD Shrink is ripping? If this has already been discussed, a link will be fine. Thanks.
I don't think you can re-author in shrink and save directly to media, it's been a while since using shrink for me...You can use DVDFAB Platinum to copy directly to media w/o copying to HDD.......there is a 30 day free trial and you won't regret it!...at least don't think you will......good luck!
By not copying to HDD ,I mean it has a feature to delete files automatically after completion.... 8)" Who needs Google, my wife knows everything"
do you know a good freeware hard drive copying program?
By edong in forum ComputerReplies: 10Last Post: 25th Aug 2016, 21:50 -
Problem copying DVDs to hard drive (previously copied from videos)
By avz10 in forum RestorationReplies: 4Last Post: 2nd Mar 2010, 23:54 -
copying a Windows XP hard drive
By joecass in forum Newbie / General discussionsReplies: 2Last Post: 10th Jan 2010, 11:00 -
Copying and converting files to external hard drive
By soxenme in forum Newbie / General discussionsReplies: 4Last Post: 25th Feb 2009, 18:16 -
Copying Your Hard Drive
By wulf109 in forum ComputerReplies: 6Last Post: 9th Feb 2008, 00:13
