I can't for the life of me get these two clips color matched (see images below). So far I have dragged the color match effect to the clip I want to adjust and then selected samples for each of the color match areas in the source clip (the one on the left) and then applied them to their corresponding target areas in the blue-ish clip. However the result is what you see in the second image (look at the top right image - it's worse, now with a purplish tint).
Can anyone please advise on what I need to do to get these clips matched (right clip matched to the left)?
Originals
After color matching
Yup. I've tried to eliminate that but that last little bit is a nightmare to correct. Anything I try now just seems to take it further away. It's a shame the tools in Premiere Pro CS3 for color correction aren't as good as those in Avid Liquid. I would have been able to get a match in a few minutes in Liquid.
In this case I am not running the two clips side by side and so they won't look too different to most people when viewed in the context of the video.
removing just one color with Premiere Pro
By spicediver10191 in forum EditingReplies: 7Last Post: 27th Apr 2016, 16:41 -
Color Primaries In Cs5 Premiere
By betonz in forum Newbie / General discussionsReplies: 0Last Post: 20th Jul 2010, 23:07 -
Correct settings for MPEG-4 AVC/H.264 for Premiere Pro 1.0 (Premiere 7.0)
By urpq32 in forum EditingReplies: 2Last Post: 24th May 2010, 05:22 -
logitech pro 9000 captured video to premiere pro CS3?
By yunakokimama in forum EditingReplies: 1Last Post: 15th Oct 2008, 17:27 -
Matching different video clips/Zooming in on audio in Adobe Premiere
By PharmBoy in forum EditingReplies: 3Last Post: 20th May 2007, 16:42
