and It works but there this green bar on the right side of the mpg when I play it back, What did I do wrong? Is there a way to fix it?
You might look for a free version of TMPGenc and just use it to do the conversion. You'll get better results. I rarely use Super, but when I get something like this, I just have to re-do the encode. You might also try that as re-running the encode might give you good results. Most likely you did nothing wrong, but Bjs' advice is sound. Seeing the results of Gspot would help us to have an idea of what you did. Or you could just tell exactly what settings you used during the encode with Super.
How to batch convert mpg to avi
By roberta in forum Newbie / General discussionsReplies: 3Last Post: 18th Apr 2011, 17:17 -
What is AVI(for pocket PC) in Super?and keep aspect ratio in Super ?
By SingSing in forum Video ConversionReplies: 2Last Post: 19th Dec 2009, 22:05 -
Using SUPER to convert AVI to FLV; afterwards...how to upload?
By jmcconnell86 in forum Video ConversionReplies: 1Last Post: 13th Jul 2009, 20:48 -
How to convert an mpg file to avi
By spyros in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2008, 16:02 -
trying to convert an Xvid avi to mp4 w/ SUPER. audio is out of sync!
By cduval04 in forum Video ConversionReplies: 3Last Post: 10th Oct 2007, 19:45
