Ok so I have hunted around and am looking for the easiest way to do this.
I have a movie with idx/sub files. ONE LINE OF DIALOG is whispered in the movie and I want it to be hard subbed on the avi file so as to not have to turn on the subs, watch the one line, then turn off the subs.
Is there a program that goes thru the idx/sub files and finds out what subs the source dvd forcable turns on, and then hard code ONLY those subs to the video?
I only want this ONE LINE of dialog subbed, not the whole file.
Note: vobsub wont install, but i did get the VSfilter.vdf thing to load.
Create a .SRT file that contains only the text you want to hardsub:
Example:
00:01:03,110 --> 00:01:05,550
This is the line that I want to hardsub.
Or, if that one line is really forced, open the IDX in Notepad, and scroll down from the top until you come to this line:
And change the OFF to ON.# ON: displays only forced subtitles, OFF: shows everything
forced subs: OFF
You can confirm that line is forced by opening the IDX in SubResynch (comes with VobSub). To the right is a column saying "Forced". As you scroll down, any and all forced subs will be marked as such. You can also highlight each line of dialog and see what it is. -
cool guys, Here is what i ended up doing but maybe you have a better way
i used divxland to make the sub files for the two lines (but that bit about finding forced subs will come in handy with the next project, a movie where all the bad guys speak a dif language and are subbed). I took the ssa file i made in divxland, loaded it in virtualdub with subtitler plugin, and then had to reencode the whole movie.
i tried cutting the movie into 3 bits (before subs, subs, after subs) thinking i could only reencode that 30 seconds and then paste all 3 back together using direct stream, but it cannont append segments with different encodings (the original movie is some well encoded xvid with ac3) and when i tried it said i had incompatible data. This is gonna suck as the movie is cut into 2 1-hour long pieces and i wanted to reencode them into one 2 hour piece and now i cant without reencoding both hours.
also, does the .divx container know how to handle FORCED subtitles, as in when i load up the .dvix movie, it will display the forced subs and none others? Then the question is, can you use surround sounds audio (ac3) in .divx container? And if you cannot then will there be a .xvid container that does allow ac3 audio?
Thanks guys.
How easy are forced Subs?
By stephens in forum SubtitleReplies: 0Last Post: 6th May 2010, 13:19 -
Forced Subs WAY Out Of Sync
By Anakin in forum Video ConversionReplies: 8Last Post: 20th Apr 2009, 10:50 -
Multiple Divx/Xvid files on DVD w/ menus and selectable subs?
By louv68 in forum DVD RippingReplies: 4Last Post: 18th Jul 2007, 09:01 -
Determine if forced subs are on a DVD
By whatisk in forum Newbie / General discussionsReplies: 0Last Post: 4th Jul 2007, 19:42 -
I can't add subs to a DivX file I have for some reason...
By darkzero297 in forum SubtitleReplies: 1Last Post: 4th Jul 2007, 19:41
