hi i am new to this form this is a wonder full site thanks for helping
i am using winavi convertor
i want to convert dvd to avi in 700 mb
could any one plse tell me the settings like frame rate and pictures size what should be used while converting with good quality in 700 mb
or if there is any good convertor for dvd to avi pls let me know with seetings
thanks and wating for your answers
For DVD to AVI (Assuming Xvid or Divx), AutoGK or FairUse Wizard. FUW may be the easiest. They both have freeware versions.
AVI to DVD, ConvertXToDVD or one of many standalone MPEG encoders..
The bitrate depends on the length of the video. You can use a bitrate calculator to see what the bitrate for a desired file size will be. Bitrate calculators: https://www.videohelp.com/tools/sections/bitrate-calculators
Just for example, I'm converting SVCDs to Xvids at present. I use about 1100Kbps with a framesize of 640 X 480, along with a deinterlace filter. These come out at about 800MB average. At 1000kbps, they would come out closer to 700MB. I convert the audio to MP3 CBR 44100kHz, 128kbps Stereo.
And welcome to our forums.
thnaks i tried the fuw i used dvd dcerypter and created an 1so file after i used fuw and after going to step3 i am getting a error messae
the dvd could not be converted
>>>>unable to create temfile
pls can u help me in this
thanks for your soupport sir
wating for your answer -
i got this message in the destination folder of fuw i used
02:39:50 456 FairUse Wizard 2.6 log file
02:39:50 456 2 processor(s) detected
23:08:09 792 FairUse Wizard 2.6 log file
23:08:09 792 2 processor(s) detected
23:13:58 792 DvdCache::_PhysicalInit() : initialising physical dvd access
23:13:58 792 NtScsi: Checking drive E:
23:13:58 792 : Index 4: fh == 00000540
23:13:58 792 Device E: Port=1, PathId=1, TargetId=0, Lun=0
23:13:58 792 NtScsi: Adding drive E: (1:0:0)
23:13:58 792 ========================================
23:13:58 792 Drive detection
23:13:58 792 => Using SPTI
23:13:58 792 Added drive E: (1:0:0)
23:14:05 792 Opening project, 38157 MB left on drive C:
23:14:05 792 ------------------------------------------
23:14:05 792 title=1, chain=0 (cells=1, duration=40)
23:14:05 792 chain 0, cell 1, vid 1, cid 1, from 0 to 9192, length 9193, fps=3, duration=40300
23:14:05 792 Non-handled cell command : 20 01 00 00 00 00 00 01
23:14:05 792 title=1, chain=1 (cells=1, duration=40)
23:14:05 792 chain 1, cell 1, vid 2, cid 1, from 9193 to 18393, length 9201, fps=3, duration=40300
23:14:05 792 title=1, chain=2 (cells=7, duration=9316)
23:14:05 792 chain 2, cell 1, vid 1, cid 1, from 0 to 135516, length 135517, fps=3, duration=589533
23:14:05 792 chain 2, cell 2, vid 1, cid 2, from 135517 to 689771, length 554255, fps=3, duration=2410833
23:14:05 792 chain 2, cell 3, vid 1, cid 3, from 689772 to 951694, length 261923, fps=3, duration=1139233
23:14:05 792 chain 2, cell 4, vid 1, cid 4, from 951695 to 1176565, length 224871, fps=3, duration=978033
23:14:05 792 chain 2, cell 5, vid 1, cid 5, from 1176566 to 1604893, length 428328, fps=3, duration=1863300
23:14:05 792 chain 2, cell 6, vid 1, cid 6, from 1604894 to 1902599, length 297706, fps=3, duration=1295200
23:14:05 792 chain 2, cell 7, vid 1, cid 7, from 1902600 to 2141950, length 239351, fps=3, duration=1041100
23:14:05 792 title=1, chain=3 (cells=1, duration=0)
23:14:05 792 chain 3, cell 1, vid 2, cid 1, from 2141951 to 2141991, length 41, fps=3, duration=600
23:14:05 792 Demux::_DemuxChain() : dvdUdf->Encrypted() tells us the chain is not encrypted
23:14:05 792 _IndexProgress() : Building program chain index...
23:16:59 792 _IndexProgress() : Grouping sections by video type...
23:16:59 792 _IndexProgress() : Synchronising streams...
23:16:59 792 _RangeInit()
23:16:59 792 Exiting _RangeInit();
23:16:59 792 Entering _RangeActivate();
23:16:59 792 NTSC video
23:16:59 792 Setting ranges
23:16:59 792 ================================================== =====================
23:16:59 792 AC3 Audio 3 = Stream 3
23:16:59 792 Audio track found: 03: Unknown, AC3, 192k/2.0
23:16:59 792 Loading subtitles
23:16:59 792 Subtitles loaded
23:16:59 792 Could not open logo file
23:16:59 792 Failed to load logo bitmap
23:16:59 792 Finished chapters setup;
23:16:59 792 Exiting _RangeActivate();
23:17:09 792 AutoModeNtsc::Process() : _problem.Worst() = 9, _ThresholdProblem = 10
23:17:09 792 AutoModeNtsc::Process() : NTSC IVTC mode
23:17:09 792 ================================================== =====================
23:17:09 792 AC3 Audio 3 = Stream 3
23:17:09 792 Audio track found: 03: Unknown, AC3, 192k/2.0
23:17:09 792 Audio track added: 03: Unknown, AC3, 192k/2.0
23:17:10 792 _IndexProgress() : Loading program chain index...
23:17:11 792 _IndexProgress() : Grouping sections by video type...
23:17:11 792 _IndexProgress() : Synchronising streams...
23:17:11 792 ================================================== =====================
23:17:11 792 AC3 Audio 3 = Stream 3
23:17:11 792 Audio track found: 03: Unknown, AC3, 192k/2.0
23:17:12 792 Audio track added: 03: Unknown, AC3, 192k/2.0
23:17:12 792 -----------------------------------------------------------------
23:17:12 792 Encoding settings :
23:17:12 792 _TranscodeProcess() : Encoding part 1 of 1
23:17:12 792 _TranscodeProcess() : Starting pass 1
23:17:12 792 Could not open logo file
23:17:12 792 Failed to load logo bitmap
23:17:12 792 ResizePlane::Create() : using Soft Bicubic resizer
23:17:12 792 ResizePlane::Create() : Resolution : 720x480 (6,12-702,458) to 400x288
23:17:12 792 ResizePlane::Create() : Resolution : 360x240 (3,6-351,229) to 200x144
23:17:12 3292 Total frames = 279481, Total duration = 9325.349367, Framerate = 29.970
23:17:12 3292 Frames = 279482, Duration = 9325.382733
23:17:12 3292 Desired size = 700
23:17:12 3292 Bitrate = 489, Size = 574284752
23:17:12 3292 DivXCodec::Create() : Failed to open internal XviD codec
23:20:45 792 _TranscodeProcess() : The DVD could not be converted
23:20:45 792 Audio track added: 03: Unknown, AC3, 192k/2.0
pls help me in this sir
one agin thanking you
soft -
How much space do you have on your disk drives ?
Do you have Xvid installed ? (note : I'm not asking can you play back Xvid files, I am asking if you have the Xvid codec installed)Read my blog here.
yes i installed xvid codic 1.1.3
and i have 40 gb free space in my hard disc
thanks for your reply
Best/Fastest .avi to dvd convertor/burner?
By xxnonamexx in forum Video ConversionReplies: 2Last Post: 24th May 2010, 20:53 -
Best settings to use when converting AVI to DVD for 624x464 files?
By Cobra281 in forum Newbie / General discussionsReplies: 5Last Post: 26th Sep 2008, 17:45 -
Winavi Stuck while converting Rmvb to avi.
By godbowen in forum Newbie / General discussionsReplies: 2Last Post: 2nd Aug 2008, 11:02 -
Converting .mov file to DVD with WINAvi
By Bachskratcher in forum Newbie / General discussionsReplies: 3Last Post: 7th Nov 2007, 12:50 -
Configuring settings when converting to AVI (DivX codec)
By firas_hashim in forum Video ConversionReplies: 15Last Post: 24th Jun 2007, 03:21
