    Feb 2005
    Canada
    I've 3 .avi files which are in Xvid format and after using avidemux to join them (append)....using MPC under properties it's telling me it's now DivX? Do I need to install Xvid?
    I've:
    ffdshow_rev1349_20070710_xxl
    MPC - Homecinema v1.0.9.0
    Thanks in advance.
    Apr 2004
    Miskatonic U
    Mode should be set to copy for audio and video when joining. This should produce the same result as Direct Stream Copy mode in Virtualdub - no re-encoding. Worst case it has changed the FourCC code to Divx.
    Read my blog here.
    Feb 2005
    Canada
    Thanks guns1inger 8), where do I set 4Cs to XviD?
    Apr 2004
    Miskatonic U
    I think you need a separate application to do this. FourCC Changer or similar should do the job. It won't make any difference to the playback.
    Read my blog here.
    Feb 2005
    Canada
    Thanks again guns1inger from an appreciative tigerb.
    Best regards.
