I have an avi file that contains two languages, one spanish and one english.
Ive tried both ffmpeg and mpeg2encoder. With mpeg2enc I tried both to encode using quicktime and mplayer, the last to no avail. The film is an ntsc film.
I have selected audio track 0, 1 and 2 but the none of the three attempts produced the english audio track.
How can I choose the right track?
You can use VirtualDubMod and the Streams menu to disable an audio track. You then save it as a new AVI using "Direct Stream Copy" in the save dialog (should only take a minute or so with Direct Stream Copy). When you disable an audio track it is excluded from the saved file, leaving you with an AVI with only 1 track. Makes converting much less of a headache
Impossible to see the future is. The Dark Side clouds everything...
How to choose audio track in avi file with two audio tracks
By newnews in forum AudioReplies: 3Last Post: 26th Oct 2010, 05:26 -
Converting ISO/IMG to AVI: How to choose the desire audio track ???
By htp367 in forum Video ConversionReplies: 3Last Post: 19th Jul 2009, 12:11 -
Vdub choose audio track
By Soixante in forum EditingReplies: 2Last Post: 25th May 2008, 12:45 -
Forcing English as the audio track to choose while playing mkv
By Wolverene in forum AudioReplies: 0Last Post: 30th Nov 2007, 10:35 -
choose audio output by application?
By rallynavvie in forum ComputerReplies: 3Last Post: 22nd May 2007, 01:03
