Im having a problem with a dvd i bought from america it dont play on my dvd player its NTSC so im guessing im going to have to convert it to PAL...(is the correct)
If so which is the easiest way to convert it to PAL without lossing any quailty or any of the menu fetures extra bonus's etc
Could someone please help me with this...
Thank You
C
Results 1 to 10 of 10
It might be a region lock issue. NTSC is supposed to play on pal from everything I've read here.
Try using a dvd ripper like dvd decrypter or a newer one like ripit4me or dvdfabdecrypter. Then burn it to a new disc without converting it. If it plays the burnt copy then it was a region lock issue.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
good luck.
If that isn't it than you might have to try the ntsc to pal conversion. Do a forum search and you'll find tons of information on how to do it.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
https://www.videohelp.com/guides?searchtext=convert+ntsc+to+pal&tools=&madeby=&formatco...or+List+Guides
This is the post's i found i was thinking of using:
How to convert a PAL DVD to a NTSC DVD using TMPGEnc Plus 2.5x
As i have TMPGEnc Plus 2.5
But does that convert the whole dvd to pal or just the movie section? because i want the menu, bonus featues and deleted scenes to work... -
That guide is how to convert a PAL DVD to NTSC and not the other way round as you want to do. Very few US NTSC DVD players will play PAL discs, whereas ALL European PAL DVD players will play NTSC discs. The problem you have has nothing to do with the format but the Region Coding. If the disc was bought in the US, it will be Region 1, your player will be Region 2.
You need to either make you player multi-region by using a hack if one is available (so it ignores the region coding) or, as has been suggested, make a region free copy of the disc. Simply use DVD Decrypter, or DVD Fabdecrypter to copy it and it WILL play. -
almost impossible to convert between NTSC and PAL and keep menus. Plus converting will reduce the quality.
You're getting that error because you are starting a PAL project in TDA and trying to import NTSC video
Why are you using TDA for anyway ?? unless you are trying to reauthor the disc with new menus, cut things out, ect. You don't need to use TDA.
If you just try what Yoda said, rip the original with DVDFab HD Decrypter, the files on your PC are now region free, burn back to dvdr with ImgBurn, the final dvd r will now be "region free" although still NTSC format and 99.9% will play on PAL equipment.
If it is too large to fit on a single layer dvdr, either run through DVD Shrink or burn back to a DL dvd+r.
Very simple, 2-3 steps at the most!! -
Noahtuck my bad i wernt ment 2 post that in this thread it was ment to be in my other thread lol... check it out may b you can help me with that:-
https://forum.videohelp.com/topic333113.html#1727707
Subs work on PC/VLC Player...but don't show up on dvd player
By bgart13 in forum SubtitleReplies: 9Last Post: 22nd Aug 2009, 19:06 -
Backup DVD can't be read normally, menus don't work
By chtit_draco in forum DVD RippingReplies: 7Last Post: 18th Apr 2009, 10:30 -
so many hours and than it don´t won´t to work. DVD Slideshow GUI problem
By d.enz in forum Newbie / General discussionsReplies: 10Last Post: 5th Mar 2009, 13:49 -
Daytek DVDR-P30 what brand DVD+R do you use? my HP 16x DVD+R don't work
By buzzinhornets in forum DVD & Blu-ray RecordersReplies: 5Last Post: 19th Oct 2007, 23:22 -
Dvd's don't work after a while.
By FreeDiver in forum DVD & Blu-ray WritersReplies: 15Last Post: 11th May 2007, 01:46
