I have some movie clips that I have downloaded in MPEG1 format. Since they are already in MPEG I decided to try burning them to a vcd without doing anything to it. Nero accepted the file and burned the vcd. Unfortunately, when I put it in my stand alone dvd player, thepicture rolls(like a bad vertical hold for those who remember). I tried puting the file through TMPGEnc, but it said there was a floating point error or something like that. I really want to get these on VCD, but I am not sure what to do at this point. Any ideas?
I need to add a few things. This is the Centropy version of LOTR and if I remember correctly, when I looked at the properties of the files it said the frame rate was around 25 which may be the problem. I'm not at home so I can't check right now. That seems not to be true as the frame rate is not displayed in properties.
TMPGEnc says it is an "Illegal floating decimal point calculation order" when I try to open the file.
I was able to get TMPGEnc to open the file by going into Options/Environmental settings and changing the priority of the DirectShow Multimedia File Reader from 0 to 1(under VFAPI plug-in). This got me something that I could burn to VCD and looks very good. Unfortunately, about 10 minutes of the audio(near the beginning) is being dropped, but the 10 minutes being dropped is in the original file I have. Any suggestions?
How to resize and convert MPEG-2 file so I can work with them in PrPro CS4?
By tomchook in forum Newbie / General discussionsReplies: 7Last Post: 13th Apr 2012, 12:02 -
Fixing / hex editing a corrupt MP4 - paid work?
By geefin in forum Newbie / General discussionsReplies: 0Last Post: 22nd Feb 2011, 04:19 -
CONVERTING MPEG 4 TO MOV FILE, ONLY FIRST 30 SEC OF CLIP WORK,help please !
By Haymaker in forum Video ConversionReplies: 5Last Post: 11th Aug 2010, 18:14 -
Fixing corrupted MPEG-1 VCD (freezing issue)
By headless chicken in forum EditingReplies: 11Last Post: 4th Sep 2009, 23:55 -
VCD MPEG playing won't work in WMP11...
By fabvideohelp in forum Software PlayingReplies: 6Last Post: 22nd Nov 2007, 13:25
