Results 1 to 22 of 22
    Sep 2006
    Good looking site, good tips
    You know I am thinking what steps does this forum takes to prevent from what happened to PC Flank and other computer forums. I wouldn't want to see this forum to bee taking over by spammers and hackers
    moved to another forum, nobody likes me here...
  2. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    One of the best forms of protection is to not discuss the protection measures you've taken. That way the would be hackers don't know what to look for.
    Buy My Books
  3. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Ah, the "security through obscurity" theory. So the only input you'll get is when one day you discover you've been hacked.
  4. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    No, not the "security through obscurity" theory. That would mean not taking protective measures and hoping nobody notices. I mean if you don't discuss what measures you've taken then a hacker doesn't know where to start and what methods can be eliminated up front. It's more the case of "I don't know what I'll have to get through there, but I know exactly what to look for from that guy that told me everything he's doing to protect his system so it will be easier".
    Buy My Books
    Sep 2006
    Lets through in another example...CNN is showing from time to time this program that is called something like The Biggest Terrorist Treats or something like that. On this program they are showing to the entire world which places in America are best targets for terrorist attack. Think about that and compare it to hackers.
    Feb 2004
    Australia
    I thought it might be handy for those recently asking about blank video when it came to using firewire ... but the rest is worth a look .
    As for security ... if you never hand over the keys in the first place , it makes it harder only ... if they want in , they'll get in ... when it comes to pcs ... they cant if its not connected or turned on in the first place .
    Yes , fLYtRap , I saw that to ... but do you believe them ... or are they hiding the real targets ... its the later ... there are better , more fearfull targets to be had that were not mentioned ... and I'll never tell .
    It aint a cold or a flu thats coming ...
  7. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    If you happen to fall into the whole "SKY IS FALLING" group...which most don't.
    Sep 2006
    I have no clue what are they doing This was really good forum just a few days ago and look at them now. It is not only they will loose forum but probably the site to and all they have to offer.
  9. Originally Posted by fLYtRap
    I believe you are referring to crackers. There is a difference.
    I don't mean to overly tease you, but I have a difficult time taking you seriously when you originally did not take any steps to protect yourself and then try to play yourself off as a security expert. :P
    Believing yourself to be secure only takes one cracker to dispel your belief.
    Sep 2006
    I never tried to play a security expert ...thats funny...anyways I am learning
    Update:
    I got used to it...people that do not really know me they think of me as I'd be 2 different persons
  11. Member lacywest's Avatar
    Aug 2001
    California
    Very good info ... actually helped me solve a problem ... under the topic
    When Win XP doesn't start ... answer was ... corrupted registry
    From the webpage ...
    How to recover from a corrupted registry that prevents Windows XP from starting
    Again, if you are treating your issue as if it is a corrupt system registry, ignore the symptoms.
    Symptoms: When you try to start or restart your Windows XP-based computer, you may receive one of the following error messages:
    Windows XP could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM <<< [I got that message on my wife's PC]
    Windows XP could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SOFTWARE
    Stop: c0000218 {Registry File Failure} The registry cannot load the hive (file): \SystemRoot\System32\Config\SOFTWARE or its log or alternate
    System error: Lsass.exe
  12. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Providing the forum software is up to date it is as secure as can be expected. The current version of phppbb2 hasn't had a update in quite some time... this is good thing. The forum software isn't the only thing that can be vulnerable though, server software, mods etc. You need to keep it all up to date just like you do any software. Spammers are another story because most of them are bots, they are stupid and that's their weakness. Baldrick said he was going to implement a question mod shortly which will all but stop them in their tracks except the human spammers which are easily spotted and rare.
    Besides this forum has stayed relative;y free of spammers since I've been around.
  13. Member steveryan's Avatar
    Jan 2003
    Manchester
    fLYtRap, why is it that every post on this forum concerning security you always pop up (no pun intended) If you're so scared then don't use the internet.
    He's a liar and a murderer, and I say that with all due respect.
    Sep 2006
    Do you leave your door open when you go out?
  15. Renegade gll99's Avatar
    May 2002
    Canadian Tundra
    I agree.
    The membership at large has been pretty vigilant and quickly report spammers.
    The private "Report this Post" option makes this a very easy thing to do without the need to get into thread discussions, accusations and arguments with suspected spammers.
    I'm sure this has helped to keep things under control and probably saved some bad feelings in the cases of false alarm.
  16. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    No, that's "security through stupidity".
    Security through obscurity is security that is ineffective if the method is known. If you believe no one else will ever discover your methods, it will work.
    Read some Bruce Schneier if you are interested in the subject.
  17. Originally Posted by steveryan
  18. Originally Posted by AlanHK
    This is the method that Apple follows. Recently a virus writer for Macs, received death threats.
  19. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    It's also because Mac users just aren't like normal people when it comes to their computers
    Read my blog here.
  20. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    I leave them unlocked because I live in a nice neighborhood and I know and trust my neighbors.
    I never leave my door wide open...all my A/C will escape...that would be just plain stupid.
  21. Video Restorer lordsmurf's Avatar
    Ah yes, ignore the problem and pretend it doesn't exist.
    I have a better idea! F--ing fix it!
