    Jun 2007
    I just shot a project in high definition but I'm knew to editing in HDV so my knowledge is limited. Fortunately I will have a professional guiding me but i have a few questions before i begin.
    I have approximately 7 hours of HD footage on mini DV tapes. I shot it on a Sony Z1U. I will be editing on my new intel iMac.
    What application should i use to digitize this footage? I have access to final cut pro, express, imovie hd, ect. Are there any other/better programs for the capturing/digitizing process.
    How much space will this take up? How big of a hard drive should i plan on buying?
    Thanks!!!
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    It's already digital, no need to digitize.
    For heavy editing you may want to transcode to an intermediate codec, tho'.
    It sees quite a lot of 'Hollywood' action. You may have seen it on end titles of movies in the last year(s) or so.
    25 Mbit/s = 3.125 MB/sec = 187.5 MB/min = 11 GB/h = 77 GB/7h for untouched storage. Multiply that several times for editing with an intermediate codec, trying out several versions of editing, et cetera, and you'll be wanting a TB in no time.
    Sep 2006
    So what "brand " of HD/Blueray burner do you have...??
    What brand of HD/Blueray disks do you plan to use???
    Play on the computer??....no problem.......
  4. Member brucejackson's Avatar
    Dec 2007
    I have Mac Pro 2.8 8 core and final cut studio 2 for my main editing system and I love it.
    I also have a PC that is using sony vegas and premiere for my part time editor.
    I love to use FCP to capture and I don't think there is a better one for Mac.
    as for the transfer rate. 1080i/29.97 with 2 channel audio will require 3.13 MB/s, I shoot 720/24P for wedding and it will require 2.38MB/s for each layer.
    I use firewire 800 RAID as my scratch disk, set up as RAID 1 to maximize the protection.
    Got the 1TB for $399 and with RAID 0, 1 and JBOD
    http://www.timelinedigitalinc.com/caldigit-raid-solution-caldigit-firewirevr-c-25_28.html
    You can also get 2 firewire drive and use os stripe under disk utility but I don't feel comfortable using os RAID.
  5. 11-13 Gig is a good number for every 60 minutes of mpeg2 HD. Final Cut would be your best choice on the Mac. As for PC well there are definately quite a few options. I personally recommend a capture drive, and an export/render drive, completely separate of each other.
    Final Cut Pro...absolutely. Load your Mac up with 4GB of RAM (<$100, I see you have 2GB now). Agree with the two external drives; one to the FW400 port and the other to the FW800 port. If your external drives are only FW400, that's okay; just get a FW800>FW400 cable or adapter. (If your drives are FW800, reverse what I said.)
    When you edit with FCP, be sure that you're not running other stuff; you want to reserve all the cajones for FCP.
