Hi all
I wonder if anyone here can give me some suggestions regarding a bunch of flv files that I like to improve their volume which is very low and when converted to ie avi (xvid or Dvix) contain lots of hissing.
Should I convert them to other format and then demux, correct the audio stream and remux?
What are the best tools to use for this job?
Thank you
You could always use FLV Extract on the FLVs, which would give you an AVI video stream (no audio, FLV or VP6-encoded) and an MP3 audio stream. Then, all you'd need to do would be to edit the MP3 however you want, re-encode the AVI for DivX/Xvid, and then mux the AVI and MP3 together.
If cameras add ten pounds, why would people want to eat them? -
then mux audio to the avi,
and try the following,
or adapt it
https://forum.videohelp.com/topic314909.html?highlight=gain
gl -
Thank you for your replies
I may have to do some audio restoration to wipe out the hissing.
Low Volume on Playback
By SE14man in forum Software PlayingReplies: 6Last Post: 28th Aug 2010, 12:45 -
Low audio volume
By Daz_uk in forum Capturing and VCRReplies: 0Last Post: 29th Jan 2010, 14:34 -
new motherboard, headphone volume too low
By gooberguy in forum ComputerReplies: 4Last Post: 9th Jul 2009, 19:37 -
Youtube: why the low volume?
By kevs in forum MacReplies: 3Last Post: 23rd Nov 2008, 07:07 -
volume too low on video file
By sepultura in forum Newbie / General discussionsReplies: 2Last Post: 28th Jan 2008, 02:46
