if it helps, here's a similar thread where someone wanted to create a tattoo...
https://www.videohelp.com/forum/archive/simulate-a-tattoo-t330194.htmlI am just a worthless liar,
I am just an imbecil -
The last couple of version of After Effects have had the Photoshop clone tool set up so it can track and clone. You will still have to do a lot of manual key framing to keep the tracking true, but it might help. If you only have a few frames then you might find it easier to export the frames, touch them up in photoshop (or Gimp if you don't have a stills editor), then bring them back in.
Read my blog here.
Open the file in virtualdubmpeg2, locate and isolate the clip you want, then use File -> Save Image Sequence to create a series of stills to work from. They will be numbered, and can be loaded in Vegas after editing to form a new clip.
Read my blog here.
removing subtitles
By natty in forum Newbie / General discussionsReplies: 12Last Post: 22nd Apr 2009, 16:08 -
removing norton
By romanstopme in forum ComputerReplies: 7Last Post: 16th Dec 2008, 06:31 -
Removing subtitles
By hostofsorrow in forum Newbie / General discussionsReplies: 2Last Post: 15th Jan 2008, 19:06 -
Removing Menu
By masterpkg in forum Authoring (DVD)Replies: 1Last Post: 27th Aug 2007, 04:05 -
[?] Simulate a Tattoo?
By #1 Stunna in forum EditingReplies: 28Last Post: 28th May 2007, 13:31
