I just purchased a new Philips DVP642, manufactured 4/07. I am unable to readout the version by opening the tray and entering 5 6 9 OK. Each button press just displays the inhibit hand and does nothing. Has the code changed or am I doing something wrong?
Irwin J. Gordon
Probably. Did you look at the back of your machine? I should have a printed label. It might have that info.
https://www.videohelp.com/dvdplayers -
The new version of the 642 uses different hardware and firmware. There is a thread here somewhere which lists the various known issues of the "new" 642 (one of them being the firmware can no longer be flashed). If you just got the player, I would consider returning it and getting one of the newer models...such as the 5960.
Google is your Friend -
I would strongly second this as an owner of a first generation DVP-642. There really is no reason to get one of these models now that Philips has better models like the 5960 available for not much more than the 642.Originally Posted by Krispy Kritter
Unable to launch version 2.5
By Schone in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 2nd Feb 2009, 08:56 -
Premiere Pro CS3 unable to edit HDV??? (not trial version)
By Digipat in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 10th Feb 2008, 00:12 -
LG RH1888H unable to read discs
By robin c in forum DVD & Blu-ray PlayersReplies: 3Last Post: 20th Nov 2007, 10:48 -
Unable to read or format DVD+RW disc
By alegator in forum ComputerReplies: 4Last Post: 8th Oct 2007, 12:11 -
TMPGEnc Author Version 2.0 - Unable to make a DVD with a motion Menu
By tug_hill2 in forum Authoring (DVD)Replies: 5Last Post: 28th Sep 2007, 01:37
