    Jul 2007
    Hello I need some help. I am using winavi 7.7 to convert films when they are finished converting my film has popup block in it. The codecs i am using is K-lite 3.2.5 Full Divx 6.6. I am not sure what else to do from this point. What is the best Codecs to use for the best quality with less repeat work. I Need help ASAP.
    Twister
  2. Banned
    Jun 2007
    UNREACHABLE
    Drop WinAvi, use VirtualDub. Besides, use the old K-Lite codec pack that contains the
    fully-functional version 5.2.1 of DivX. HTH.
  3. Member buttzilla's Avatar
    Apr 2007
    Deep Space Nine
    I would update to the new winavi 8.0. i found 7.7 to be very buggy.
    Apr 2004
    Miskatonic U
    I wouldn't touch WinAVI or K-lite with a barge pole. Both are rubbish, will cause you problems down the track, and will make your life miserable.
    Use AutoGK or Dr Divx for Divx/Xvid encoding.
    Read my blog here.
