Is there any software available that can run on
a computer with a Celeron processer 467MHz
with 160MB of RAM?
Thanks in advance.
If your video card supports DXVA, I would go with the Nvidia PureVideo. It's not free but it's the best one I've found. And I've tried just about all of them.
Although, that sounds like an older card? It may not support DXVA. -
Diamond Viper V330 ... dose that bring back some memories ... I had a diamond monster , 32mb , fusion drivers ... what a brute
Forget it
Its really too slow to playback dvds at a rate that will not produce stuttering .
They used to make a pci card , years ago , that allowed slower ended systems to playback dvds in real time , but there almost extinct ... ebay would be your best bet in finding one of them now ... just dont recall it by name off hand ... its way back .
Once you have that , you then need to deal with the issue of dvd playback software that might go a little easier on the system , and not be a hog on resources .
Koolplaya + freedvdcodec (its out there) + ac3filters ...and away you go ... how fast , would be a guess ... not fast enough I suspect .
Check your motherboard for cpu's supported , you might find it can support ... anywhere near 800mhz cpu would be fine ... again ... ebay for that ... simple process provided the socket type is correct .
Hopefully you might beable to fit a p3 800mhz cpu ... that'll give it new life , and some thump ... and if so , you can forget looking for that pci card thingy I mentioned before ... you wont need it . -
I appreciate all the help. I figured it would be able to play dvds with
out an upgrade. Thanks again.
HD-DVD Playback Software
By Blazingstix in forum Blu-ray RippingReplies: 1Last Post: 11th Mar 2010, 22:28 -
DVD playback software that ignores UOP?
By RarelyEvil in forum Software PlayingReplies: 4Last Post: 2nd May 2009, 01:16 -
Best Software (IYO) For HD-DVD Playback
By greymalkin in forum Media Center PC / MediaCentersReplies: 24Last Post: 3rd Mar 2009, 14:50 -
Need software for HD DVD playback
By steve42069 in forum Software PlayingReplies: 5Last Post: 13th Jan 2009, 07:36 -
DVD playback software without install
By sugeknight in forum Software PlayingReplies: 4Last Post: 12th May 2007, 10:59
