Results 1 to 12 of 12
    Jul 2007
    We got a SAMSUNG SE-W164 and using Verbatim and Sony DVD+R discs. Fails. DVD+RW works. Problems with drive or disks? Burning program Nero.7 and Imgburn. Please help we're running out of money and patience.
    Errorlog from Nero;
    ********** Nero Recode **********
    Version: 2.3.7.0
    Project type: Copy entire DVD
    Target size: DVD5 (2282925)
    Burn settings:
    Target: TSSTcorp CD/DVDW SH-W162C
    Number of copies: 1
    Write speed: 0 KB/s
    Temp folder: C:\Documents and Settings\---\Mina dokument\Nero Omkodning (2723401728 bytes free)
    Direct burning: false
    Target media: DVD R/RW; DVD R DL; DVD-RAM
    Shutdown when finished: false
    Advanced Analysis: false
    Compress Adaptive: true
    18:49:57 File burn_dvdfiles.cpp, Line 238
    Compile DVD: init
    VMG Menus Vobs [1 vobus] 0.13MB -> 0.13MB [R 1.00]
    Video: 0.13MB, extra: 0.00MB
    Audio: 0 streams
    Subpicture: 1 streams
    0. 0. Ospecificerat 0.00MB [enabled]
    VTS_01 Title Vobs [7643 vobus] 2960.49MB -> 2960.49MB [R 1.00]
    Video: 2837.02MB, extra: 123.47MB
    Audio: 1 streams
    0. 0. Dolby Digital 2-ch Ospecificerat 108.54MB [enabled]
    Subpicture: 0 streams
    18:49:57 File burn_dvdfiles.cpp, Line 1245
    Compile DVD: begin copy 1
    18:49:57 File NeroRecorderBase.cpp, Line 517
    Writing to disc: D
    18:49:57 File NeroRecorderBase.cpp, Line 531
    Free capacity on disc: 2283085 sectors (2295104)
    18:49:57 File burn_dvdfiles.cpp, Line 514
    Using previously transcoded files for burning
    18:49:57 File NeroRecorderBase.cpp, Line 1392
    Burning 8 files with total size of 3104555008 bytes on hard disk
    Windows XP 5.1
    IA32
    WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 2001-02-01 15:10:18
    ahead WinASPI: File 'C:\Program\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 2004-11-02 12:54:32
    NT-SPTI used
    Nero API version: 7.5.9.0
    Using interface version: 7.0.5.6
    Installed in: C:\Program\Nero\Nero 7\Core\
    Application: Ahead\Nero Recode
    Internal Version: 7, 5, 9, 0
    Recorder: <TSSTcorp CD/DVDW SH-W162C>Version: TS07 - HA 1 TA 2 - 7.5.9.0
    Adapter driver: <USB 2.0> HA 1
    Drive buffer : 2048kB
    Bus Type : set to ATAPI (3) -> ATAPI, detected: ?
    === Scsi-Device-Map ===
    DiskPeripheral : HTS548040M9AT00 atapi Port 0 ID 0 DMA: On
    CdRomPeripheral : PHILIPS CDRW/DVD CDD5263 atapi Port 0 ID 1 DMA: On
    === CDRom-Device-Map ===
    PHILIPS CDRW/DVD CDD5263 D: CDRom0
    TSSTcorp CD/DVDW SH-W162C G: CDRom2
    AutoRun : 1
    Excluded drive IDs:
    WriteBufferSize: 73400320 (0) Byte
    BUFE : 0
    Physical memory : 503MB (515452kB)
    Free physical memory: 302MB (309332kB)
    Memory in use : 39
    Uncached PFiles: 0x0
    Use Inquiry : 1
    Global Bus Type: default (0)
    Check supported media : Disabled (0)
    21.7.2007
    NeroAPI
    18:49:58 #1 Phase 112 File APIProgress.cpp, Line 282
    DVD-Video files reallocation started
    18:49:58 #2 Phase 114 File APIProgress.cpp, Line 282
    DVD-Video files reallocation completed (no file modified)
    18:49:58 #3 Phase 111 File APIProgress.cpp, Line 282
    DVD-Video files sorted
    18:49:58 #4 Text 0 File SCSIPTICommands.cpp, Line 411
    LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
    18:49:58 #5 ISO9660GEN -11 File Geniso.cpp, Line 3332
    First writeable address = 0 (0x00000000)
    18:49:58 #6 ISO9660GEN -11 File Geniso.cpp, Line 3332
    18:49:58 #7 Text 0 File Burncd.cpp, Line 3451
    Turn on Disc-At-Once, using DVD media
    18:49:58 #8 Text 0 File DlgWaitCD.cpp, Line 306
    Last possible write address on media: 2295103 (510:01.28, 4482MB)
    Last address to be written: 1516431 (336:59.06, 2961MB)
    18:49:58 #9 Text 0 File DlgWaitCD.cpp, Line 318
    Write in overburning mode: NO (enabled: CD)
    18:49:58 #10 Text 0 File DlgWaitCD.cpp, Line 2903
    Recorder: TSSTcorp CD/DVDW SH-W162C, Media type: DVD+R
    Disc Manufacturer ID: MCC, Media Type ID: 004, Product revision number: 0
    Disc Application Code: 0, Extended Information Indicators: 7
    18:49:58 #11 Text 0 File DlgWaitCD.cpp, Line 490
    >>> Protocol of DlgWaitCD activities: <<<
    18:49:58 #12 Text 0 File ThreadedTransferInterface.cpp, Line 821
    Setup items (after recorder preparation)
    0: TRM_DATA_MODE1 ()
    2 indices, index0 (150) not provided
    original disc pos #0 + 1516432 (1516432) = #1516432/336:59.7
    relocatable, disc pos for caching/writing not required/ required
    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1516432 blocks [G: TSSTcorp CD/DVDW SH-W162C]
    18:49:58 #13 Text 0 File ThreadedTransferInterface.cpp, Line 1024
    Prepare [G: TSSTcorp CD/DVDW SH-W162C] for write in CUE-sheet-DAO
    DAO infos:
    MCN: ""
    TOCType: 0x00; Session Closed, disc fixated
    Tracks 1 to 1: Idx 0 Idx 1 Next Trk
    1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 3105652736, ISRC ""
    DAO layout:
    ___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|__ ____NWA_|_RecDep__________
    0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
    0 | 1 | 0 | 0x41 | 1516432 | 0 | 0x00
    0 | 1 | 1 | 0x41 | 1516432 | 0 | 0x00
    1516432 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
    18:49:58 #14 Text 0 File SCSIPTICommands.cpp, Line 209
    SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
    18:49:58 #15 Phase 24 File APIProgress.cpp, Line 282
    Caching of files started
    18:49:58 #16 Text 0 File Burncd.cpp, Line 4278
    Cache writing successful.
    18:49:58 #17 Phase 25 File APIProgress.cpp, Line 282
    Caching of files completed
    18:49:58 #18 Phase 36 File APIProgress.cpp, Line 282
    Burn process started at 16x (22*160 KB/s)
    18:49:58 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2743
    Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
    18:49:58 #20 Text 0 File Cdrdrv.cpp, Line 9234
    ---- DVD Structure: Physical Format Information (00h) ----
    Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
    Book Type: DVD+R (10), Part Version: 1.0x (1)
    Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
    Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
    Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
    Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
    End Physical Sector Number of Data Area: 26053F h
    End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
    Data in Burst Cutting Area (BCA) does not exist
    Disc Application Code: 0 / 0 h
    Extended Information indicators: 7 h
    Disc Manufacturer ID: MCC.....
    Media type ID: 004
    Number of Physical format information bytes in use in ADIP up to byte 63: 56
    Media Specific [16..63]:
    00 00 07 4D 43 43 00 00 - 00 00 00 30 30 34 00 38 ...MCC.....004.8
    23 54 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 #T..............
    00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
    18:49:58 #21 Text 0 File Cdrdrv.cpp, Line 9234
    Media type ID: 004
    18:49:58 #22 Text 0 File Cdrdrv.cpp, Line 9234
    Media type ID: 004
    18:49:58 #23 Text 0 File DVDR.cpp, Line 8070
    Drive: TSSTcorp CD/DVDW SH-W162C
    Book Type request [TSST]: DVD-ROM
    Changing the Book Type was finished successfully, return code 0
    18:49:58 #24 CDR -1207 File DVDR.cpp, Line 6174
    Book Type automatically set to: DVD-ROM
    18:49:58 #25 Text 0 File DVDPlusRW.cpp, Line 674
    Start write address at LBA 0
    DVD high compatibility mode: Yes
    18:59:59 #26 SPTI -600 File SCSIPassThrough.cpp, Line 179
    CdRom2: SCSIStatus(x00) WinError(121) NeroError(-600)
    Sense Key: 0x00 (KEY_NO_SENSE)
    Sense Code: 0x00
    Sense Qual: 0x00
    CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00
    Sense Area: 0x00 00 00 00 00 00 00 00 00 00 00 00 00
    Buffer x22040040: Len x10000
    0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    18:59:59 #27 CDR -600 File Writer.cpp, Line 299
    Device not available
    19:00:20 #28 SPTI -1114 File SCSIPassThrough.cpp, Line 179
    CdRom2: SCSIStatus(x02) WinError(0) NeroError(-1114)
    Sense Key: 0x06 (KEY_UNIT_ATTENTION)
    Sense Code: 0x29
    Sense Qual: 0x00
    CDB Data: 0x35 02 00 00 00 00 00 00 00 00 00 00
    Sense Area: 0x70 00 06 00 00 00 00 0A 00 00 00 00 29
    19:00:20 #29 SPTI -1033 File SCSIPassThrough.cpp, Line 179
    CdRom2: SCSIStatus(x02) WinError(0) NeroError(-1033)
    Sense Key: 0x02 (KEY_NOT_READY)
    Sense Code: 0x04
    Sense Qual: 0x01
    CDB Data: 0x5B 01 05 00 00 00 00 00 00 00 00 00
    Sense Area: 0x70 00 02 00 00 00 00 0A 00 00 00 00 04 01
    19:00:20 #30 Phase 127 File APIProgress.cpp, Line 282
    Generating DVD high compatibility borders
    19:00:28 #31 CDR -1114 File WriterStatus.cpp, Line 162
    Reset occurred
    19:00:28 #32 TRANSFER -24 File WriterStatus.cpp, Line 162
    Could not perform end of Disc-at-once
    19:00:28 #33 Phase 38 File APIProgress.cpp, Line 282
    Burn process failed at 16x (22*160 KB/s)
    19:00:29 #34 Text 0 File SCSIPTICommands.cpp, Line 254
    SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
    19:00:32 #35 Text 0 File Cdrdrv.cpp, Line 10467
    DriveLocker: UnLockVolume completed
    19:00:32 #36 Text 0 File SCSIPTICommands.cpp, Line 411
    UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
    Existing drivers:
    File 'Drivers\ADPU160M.SYS': Ver=v3.60a (Lab01_N(johnstra).010529-2218), size=101888 bytes, created 2001-08-17 23:07:32
    File 'WNASPINT.DLL': Ver=V1.18, size=57344 bytes, created 2002-11-05 15:16:52
    File 'Drivers\PXHELP20.SYS': Ver=2.03.32a, size=20640 bytes, created 2006-01-06 18:52:42 (Prassi/Veritas driver for win 2K)
    Registry Keys:
    HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
    19:00:33 File NeroRecorderBase.cpp, Line 1198
    Burn failed (3)
    19:00:34 File burn_dvdfiles.cpp, Line 308
    Compile DVD: exit
    Nov 2004
    Las Vegas
    askungen,
    The problem isn't the disks you're using, it's the drive, or more specifically the connection between the drive and the computer.
    The log shows that the software and the drive lost the ability to communicate, followed by a either a power-on reset, or a bus device reset of the drive. Once the software and the drive lost contact, the burn couldn't be completed.
    Since it's a USB external drive, were you doing anything else with the USB at the same time. If so, that isn't a good idea.
    You can check the USB cable connections at the computer and the external box. If they look good, you can try a different USB cable. You should also check the power connection to the external box and at the wall.
    If that doesn't work, is this a new external box/drive that hasn't worked yet, or something that used to work, but doesn't anymore?
    If it's new, you should consider returning/exchanging it.
    Nov 2004
    Las Vegas
    askungen,
    Sorry...I forgot to say "Welcome to VideoHelp".
    Jul 2007
    Thanx, for the answer. This drive has been working fine for a long time. The only other thing connected to the computer via USB is the Mouse, and its connected via anonther USB port. We will take that away. And also buy another USB cable. Mabey it will solve our problems.
    Still, the strangest thing is when you put in an DVD+RW instead of a DVD+R it works fine. Mabey just an coinsidens?
    Nov 2004
    Las Vegas
    askungen,
    I have seen references that firmware could be the cause of that problem, but I've never seen it firsthand, nor can I picture how outdated firmware could cause a shutdown - reset of the drive. However, in this case, where the drive was working, and isn't anymore, it might be worth it to you to update the firmware. After all, it's unlikely a USB cable would go bad, which raises the question of whether the drive is reaching the end of its' lifespan, or just having a really hard time dealing with media that didn't exist when your current firmware was written. In that case, a more vigorous pursuit of a solution would be warranted. A drive that burns +RW but not +R certainly sounds like a candidate for a firmware update.
    This page has a link to version TS11 firmware for your external drive. Since you currently are using version TS07, it should represent a big change. It might be safer to use the "Firmware LiveUpdate Program" which Samsung has. If you don't still have it from when you got the drive, you can get a new version of the program here. It's supposed to handle the firmware download and update automatically, which makes it easy for you, and removes human error as a factor.
    Feb 2004
    Australia
    Ah ... samsungs , you either like them ... or get rid of them
    Check "auto start" is disabled for unit , it can triger the issue
    And whoa down the burn speed , recommend half media's max , but with usb , half that again .
    Normal recommendation = 4x
    Some usb devices dont get along with others
    And it had better have its own power supply , or you'll stuff the pc right up ... usb dvd burners normally need 2 amps , you go shoving it into a pc , and your asking for "usb reset os warning" ... which means , go get a new motherboard .
    Dont use the pc while its burning
    Use imgburn instead rather than nero
    Try other dvd+r ... but dvd-r is more cross compatable .
    Jul 2007
    Very many thanks for the tips and links!!!
    Ok, now we have updated the firmware to version TS11 and the burn speed is down to 4x. We dont use the PC while burning and nothing else is connected to other USB ports. The power connection to the drive is OK. We still use the same USB cable.
    But... still the same problem. When we put in a Verbatim DVD+R;
    (excerpt from NERO errorlog)
    08:24:28 #21 SPTI -600 File SCSIPassThrough.cpp, Line 179
    CdRom1: SCSIStatus(x00) WinError(121) NeroError(-600)
    Sense Code: 0x00
    Sense Qual: 0x00
    Buffer x07150040: Len x10000
    08:24:28 #22 CDR -600 File Writer.cpp, Line 299
    E: TSSTcorp CD/DVDW SH-W162C
    08:24:51 #23 SPTI -1114 File SCSIPassThrough.cpp, Line 179
    CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1114)
    Sense Code: 0x29
    Sense Qual: 0x00
    08:24:51 #24 SPTI -1033 File SCSIPassThrough.cpp, Line 179
    CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1033)
    Sense Code: 0x04
    Sense Qual: 0x01
    08:24:52 #25 Phase 127 File dlgbrnst.cpp, Line 1746
    08:25:01 #26 CDR -1114 File WriterStatus.cpp, Line 162
    Reset occurred
    08:25:01 #27 TRANSFER -24 File WriterStatus.cpp, Line 162
    08:25:02 #28 Phase 38 File dlgbrnst.cpp, Line 1746
    Burn process failed at 4x (5 540 KB/s)
    And when we use TDK DVD+RW;
    08:49:48 #20 Text 0 File WriterStatus.cpp, Line 113
    <E: TSSTcorp CD/DVDW SH-W162C> start writing Lead-Out at LBA 2093014 (1FEFD6h), length 0 blocks
    08:49:49 #21 Phase 37 File dlgbrnst.cpp, Line 1746
    Burn process completed successfully at 4x (5 540 KB/s)
    And now a new problem has occured, When we burn to a TDK DVD+RW, Nero AND especially ImgBurn gets "Buffer underrun" Nero burns to the end, but ImgBurn has to"wait for buffer to recover" The disc also (and this happend before the firmware were updated)stops and jump back to the beginning.
    A bit confusing... adding the complete errorlog for Verbatim (fails) and TDK +RW (succeded)
    tr.tdk%20dvd+rw.cen.log.txt
    tr.verbatim.cen.log.txt
    Jul 2007
    ...and then it suddenly works... with Verbatim! Widhout changing a thing.
    11:23:24 #21 Text 0 File WriterStatus.cpp, Line 113
    11:24:31 #22 Phase 37 File dlgbrnst.cpp, Line 1746
    After burning it to a +RW disc.
    The reading buffer still doesnt work well. It sinks to 0%.The little lamp on the burner stops blinking (it indicates that the machine burns) And then the buffer rises to 100% and the machine starts to burn again for about 5-10 times during the burn process.
    verbatim%20succeded%20log.txt
  9. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Nero and/or ImgBurn reporting that the read buffer is 0, would seem to indicate that the burning app(s) aren't able to pull the data fast enough from the HDD. The burner is pulling and burning the data faster than the app can buffer and feed it. This would seem to indicate a pc/software issue and not the burner. But it doesn't help to explain why the problem varies with different media.
    Google is your Friend
    Nov 2004
    Las Vegas
    askungen,
    You're right that the same problem is still occurring. When a burn doesn't work, the logs show the following pattern:
    1) atapi error 000000 - means the computer and drive have lost communication with each other
    2) atapi error 062900 - means either there was a drive power-on reset or there was a bus device reset
    3) atapi error 020401 - means the drive is still initializing, and isn't ready yet
    If you have an external hard drive or flash drive, you could try moving a large file from-to the external device and see if there is an error with usb on your computer. If it works without error, the only thing left is some part of the external burner. An alternative check would be to plug your external burner into a different computer and see if the same problem exists. If so, it's definitely the drive...if not, your computer may be the source of the problem.
    I don't think the buffer problem you mention would cause a failure like you're getting. Even a severe shortage of data shouldn't cause a drive/bus device reset.
    Jul 2007
    Now I think the problem is solved. I found this answer on the samsung site;
    "Inferior of a driver¡¯s pick-up (when the strength of light in the lens area is weak). The OPC is the special area located in the center of a recordable CD. Before recording a data on a track of a CD, a CD recorder must control a power amount of laser to get the best level for the resent CD. The OPC is already set up to operate this operation. But in case a pick-up is an inferior, misrecognition or incorrect recording could be occurred."
    Link;
    http://www.samsungodd.com/eng/Support/Helper/Helper.asp?Functionvalue=Searchlist&Produ...de=SDR&type=13
    I know its about burning CDs but I taught it was worth trying. I bought a lens cleaner, cleaned the lens and now the DVD burner has been working fine for sveral discs (VerbatimDVD+R)!!! At the second burn a little buffer underrun occured, but the result on the disc was fine. I shall also add that I opened up the DVDburner case (it is an exernal drive) and tried to change to SONY/NEC burner. It didnt work, so I put the SAMSUNG burner back.
    Nov 2004
    Las Vegas
    askungen,
    The excerpt you posted from the samsung site concerns power calibration. If power calibration was the problem, the burn log would have reported atapi error 037303, or maybe atapi errors 017301 or 037302. Since those errors never occurred in the logs, that wasn't your problem.
    If the problem is fixed, it's most likely there was a bad connection in the external box. When you removed the drive and re-inserted it (redoing the connections), you might have gotten a good connection. To be honest, I would feel more secure in this solution to your problem if I could grasp how a connection inside an external box could go from good to intermittent.
    If the problem doesn't resurface, congratulations on finding a solution. If the problem does return, don't hesitate to post back to this thread.
