Well, not exactly freezing, but it simply stops outputting the video and stays stuck in one spot until I have to Alt-Cntrl-Dlt and end the program (the "abort output" button doesn't work in this situation).
The DVD I'm trying to output has motion menus that get "stuck" during the output process. Whenever it gets stuck, it seems to get stuck at the end of one motion menu. Strangely, it successfully finishes one or two pages of menus before getting stuck on the next page and then on the next try it will get stuck on a menu page it was able to finish on the previous try.
DVD Author 3 has worked great for me in the past when making still image w/ audio menus. I know I have the "Use Background Audio" box selected. In the simulation mode, everything works absoulutely perfect.
Does anyone have any idea why it'd stop the output process?
Convert AVI to ? to TMPGEnc DVDAuthor with 5.1 audio
By NDMMackay in forum Video ConversionReplies: 2Last Post: 15th Oct 2011, 08:02 -
Tool similar to TMPGEnc DVDAuthor that can handle DTS audio
By robertazimmerman in forum Authoring (DVD)Replies: 6Last Post: 12th Jan 2011, 12:45 -
GUI for DVDauthor - Fit/shrink output to 4.7G DVD
By pannayar in forum Authoring (DVD)Replies: 5Last Post: 14th Aug 2008, 23:49 -
Problems with TMPGENC 4.0 XPRESS + TMPGENC DVDAUTHOR 3.0 :( help
By neurosys in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2008, 19:37 -
Tmpgenc keeps freezing
By WinSpecToR in forum Video ConversionReplies: 6Last Post: 12th May 2008, 01:08
