I thought in reading various forums that I had seen at one time that although DVDShrink was no longer being updated, someone had somehow added the capability to set DVDShrink to burn automatically with ImgBurn the same way it can be set to burn automatically with Nero.
Is this possible?
I have historically used this feature and burned all my DVDs with Nero, but now I am occasionally using dl discs and want to use ImgBurn instead.
TIA
SMK
Not natively. There was a way to fake it, and there is a modified version that will use imgburn, but why do you need to tie them together ?
Imgburn doesn't require an ISO, so you don't need Shrink to create one.
You require the same amount of HDD space if you burn directly, so why not have Shrink write to the HDD first, then burn with Imgburn afterwards. This gives you a chance to test the results before committing them to a burn.
Anyways, here is a little light reading for you : http://forum.digital-digest.com/showthread.php?t=59242Read my blog here.
It's not actually for me, and I agree that there is no reason to go directly from Shrink to ImgBurn. The reason I ask is that I am helping a friend get started on backing up DVDs. He doesn't have Nero, and I thought a "one-step" process would be easier for him just starting out. He is not interested in using DVD-9's and wants to shrink everything. I thought he could use Shrink and not have to output to his HDD before burning. It would just eliminate one step.
Thanks again.
SMK -
How is he going to rip ? Apparently, if you can find it, the imgburn enabled shrink has had CSS removal taken out, so it won't rip at all. Even the old version of Shrink doesn't do to well at ripping newer discs.
And honestly, if it is only to act as a burning engine for Shrink, and not be used as a stand-alone burner, you might as well use DVD Decrypter.Read my blog here.
You are correct. I hadn't thought of just using DVD Decrypter since I never use it for burning.
Thanks a lot.
SMK -
Originally Posted by handyguy
Thank You Mr. Obvious...but he and everyone else knows that already.
Originally Posted by RoyGBiv-inRI -
This thread has a download link to the modified version of DVD Shrink that burns with IMGBurn.
http://forums.afterdawn.com/thread_view.cfm/521885
Be sure to read the entire thread to be sure you install it correctly.
Instructions for DVDShrink with ImgBurn?
By JohnnyBob in forum DVD RippingReplies: 29Last Post: 9th Sep 2010, 15:00 -
I have an Aopen Dvd Burner, how can I set booktype in imgburn?
By frieday in forum Authoring (DVD)Replies: 13Last Post: 3rd Nov 2009, 05:30 -
What label settings / file restrictions to set for ImgBurn for AVI files?
By Relayerman in forum Software PlayingReplies: 2Last Post: 14th Aug 2009, 22:22 -
Burning with Imgburn
By Ronny G in forum Authoring (DVD)Replies: 7Last Post: 16th Mar 2008, 18:37 -
DVDShrink Updated? to work with Imgburn
By Bronx in forum Newbie / General discussionsReplies: 5Last Post: 13th Aug 2007, 09:12
